Wire Gutter/Loom in Engine Bay
Guys, I have been searching the forum for sources for the wire gutters in the engine bay that go across the top of the fire wall and across the top of the radiator support. I bought a set from Classic Industries that showed up made of a hard plastic rather than the pliable rubber that was installed at the factory. The piece for across the radiator support has pre-drilled holes that do not line up with the holes in the radiator support. It also needs to bend down on each side and this plastic is too hard to make the sharp bend without creating a large arc.
Now I'm a bit nervous to order from other suppliers for fear of acquiring the same poor quality. Is there a good source for these out there? |
![]() Join Date: Sep 2014
Re: Wire Gutter/Loom in Engine Bay
Mine were the hard plastic as well and they work just fine. The holes did not line up so I drilled new ones to match the original hole locations. The originals in my 68 were hard plastic iirc.
I don't recall where I got them from sorry. Blake Last edited by MySons68C20; 07-19-2021 at 04:04 PM. Reason: Missing info |
Pics may help?
Thanks for the responses, guys. The pics sure do help. I'll be sure to include photos in future posts. The sturdy black plastic gutters sold by LMC sound similar to what I purchased from Classic Industries, so I'll be passing on that version. The Brother's version is difficult to see and the description doesn't shed any light on material but they appear to be the hard plastic as well.
I did receive a tip to check out Jim Carter Chevrolet thanks to Dale. They have a vinyl version of the gutter across the radiator that I am going to order. I'll let you know what shows up in the mail. https://oldchevytrucks.com/fpw253.html |
#6 | |
LMC has both in their catalog...
