Old 12-24-2003, 12:10 AM   #1
72superBB
72superBB's Avatar
The push in oil cap keeps blowing off!
WTH?
I changed the intake, finally got the timing right. All good right?
I pull out of the drive and go along then accelerate prety good, and then bang, it hits the underside of the hood. So I go back and thought that maybe I left it off or in loose. I look it over and adjust the timing again.
I leave again and go a little further and and boom it happens again.
I have no explanation for this one. Fix one thing, and then another happens.
OOOOOOOOOOOOooooooooooooo boy!
thanks for listening!
Ron
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 12-24-2003, 12:12 AM   #2
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
Got a plugged PCV Valve????? Too much crankcase pressure!!
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 12-24-2003, 12:14 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Had the same thing happen scared the crap outta me.. Never did fix the problem but did put in a new crate motor has not happend since.LOL
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-24-2003, 12:14 AM   #4
72superBB
72superBB's Avatar
Valve is not even a month old, but I guess I could replace to see if it changes anything. If it does not, then what?
1990 Chevy SWB
Old 12-24-2003, 12:17 AM   #5
cableguy0
your building pressure somehow that pcv valve could be stuck most likely possibility
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-24-2003, 12:18 AM   #6
DanoDMano
DanoDMano's Avatar
Can you blow through it??
Power Locks,
Truck Photos
Old 12-24-2003, 12:19 AM   #7
72superBB
72superBB's Avatar
uhhhh. blow through what?
ohh the valve! I gotcha! lol
I have not tried. I will just buy a new one in the morning to have a new one.
1990 Chevy SWB
Old 12-24-2003, 12:20 AM   #8
J.Lance
Too many is never enough!
pcv valve
rattle the pcv valve just to make sure it isn't stuck. also check the hose to the carb and the carb itself. Has to be there somewhere. Your cap is on the same valve cover as the valve right?
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
Old 12-24-2003, 12:25 AM   #9
72superBB
72superBB's Avatar
The valve is on the back drivers and the cap is the front passenger side. Where the cap is there used to be a hose going from the valve cover to the underside of the breather.
1990 Chevy SWB
Old 12-24-2003, 12:45 AM   #10
J.Lance
breather
Do you have a breather on the same side as the oil fill? That could be your problem. On small blocks anyway, they have the fill on the same side as the pcv (both sides sometimes) and the pcv provides the pressure relief for that side. The other side has the vent hose running to the carb stack. If all you have on the passenger side is the oil fill with no breather, that could be the problem. I believe this is why earlier small blocks had the oil fill through the intake since there was no pcv valve on the cover. And of course, I could be completely off base here but that is my best guess.
Jason
Jason
1971 K2500 GMC LWB
Old 12-24-2003, 12:46 AM   #11
DanoDMano
DanoDMano's Avatar
On mine the PCV is on the passenger side rear with hose to breather, the oil filler was on the drivers rear, and another hose went from the drivers front to the carb??
When I installed my New carb I went from the PCV to the carb, and then just have a filler on the drivers front.
Power Locks,
Truck Photos
Old 12-24-2003, 12:50 AM   #12
dinnut
dinnut's Avatar
your engine is haunted man.......
i would think your pcv is stuck or something.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-24-2003, 07:43 AM   #13
71-longbed
Its Magically Delicious
71-longbed's Avatar
my stock 350 is setup like is :
passenger side.... front = oil cap
......rear = flame arrestor
driver side front = pcv valve
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 12-24-2003, 11:05 AM   #14
Huck
Huck's Avatar
My pure stock 71 has the oil filler on the drivers rear and the pcv on the drivers front. It has the flame arrestor tube/hose to the carb stack on the pass rear. this setup insures pressure relief for both sides.
Huck is offline   Reply With Quote
Old 12-24-2003, 02:57 PM   #15
dinnut
dinnut's Avatar
yall are confusing me. heres what i got... is the thing on the passenger rear the pcv? and the drivers front is the oil filler/breather?
70 longbed
496/th400/Ford 9"
Old 12-24-2003, 03:21 PM   #16
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
That's how I set mine up, too. The only difference is that I eliminated the hose on the passenger side and replaced it with a breather.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 12-24-2003, 06:25 PM   #17
knucklebuster
Failure is NOT an option!
knucklebuster's Avatar
Dinnut,Thats wher the pcv should go but I can't tell if you actually have one from this pic.It doesn't look like it from that angle,only looks like a hose.
House payment or truck parts?????.........why does life have to be so complicated?
1969 Chevy Shortbed Fleetside
1969 Camaro ps pb a/c(drove in high school now it's just a yard ornament,but it's next on the list for resto)
1990 Ni$$an hardbody( daily beater that has been really beaten!)
1999 Grand Am GT(wifes ride...never buy a pontiac!!Trust Me)
knucklebuster is offline   Reply With Quote
