Old 07-19-2021, 10:18 PM   #1
cj847
cj847's Avatar
TH 350 shifts
I am having issues with my 350 transmission (I think).
First - it pulls fine in every gear and has been modified by previous owner.
Shifts are extremely fast (chirps the tires shifting at light throttle) literally a split second vs the normal shift of a 350 trans where you can actually feel the loss of power during the shift.
Under mid/heavy throttle everything shifts perfect and the kickdown is adjusted just right.
My problem:
Under light throttle (like leaving a stop sign turning left - it will shift to 2 and 3 simultaneously under 15 mph. It's like driving a powerglide. I have good vacuum and the modulator valve holds vacuum.
Any ideas?
cj847 is offline   Reply With Quote
Old 07-19-2021, 11:32 PM   #2
kwmech
Re: TH 350 shifts
May have to check the springs on the governor. Pull the modulator out and see if there is a small spring in there. Some of the shift kits will have it.
