Old 12-24-2003, 12:42 AM   #1
rage'nrat638
rage'nrat638's Avatar
****3/4 Ton Disc Conversion Questions*****
OK.....RECIEVED MY 3/4 TON DISC BRAKES FROM KILOMANJARO
THANKS JOHN......
INFO:69 3/4 TON 2 W.D. DRUM'S/ CONVERTING TO DISC
PARTS RECIEVED:SPINDLES,ROTORS, CALIPERS, HOSES,STEERING COMPONETS,....FROM A 72 I THINK
QUESTIONS:
#1 ARE THE BALL JOINTS THE SAME??
#2 ARE THE STEERING COMPONETS THE SAME...TIE RODS ETC.?
#3 WILL MY 16.5 WHEELS WORK WITH DISC?
#4 IS THE MASTER CYL THE SAME?
#5 PROVALVE THE SAME?
THANKS INADVANCE......MARK
rage'nrat638 is offline   Reply With Quote
Old 12-24-2003, 12:43 AM   #2
dinnut
dinnut's Avatar
1 ball joints probably different. 2 same steering parts i beleive although you will probably want to put new ones in just because. but the rotors and calipers in the wheels and see! master cylinder and pro valve different
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-24-2003, 12:52 AM   #3
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
master cylinder should be different (larger capacity for disc)
and proportioning valve is definately different.
check on the net for interchangeable ball joints and tie rods.
use an auto parts site to comapre part #'s
thats what i did to see what interchanged for my 70 when changing to disc.
i used autozone.com
and o'rileys web side
tommie
tommie is offline   Reply With Quote
Old 12-24-2003, 10:19 AM   #4
racedvl
racedvl's Avatar
TTT
racedvl is offline   Reply With Quote
Old 12-24-2003, 01:56 PM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
It is all different. This is one reason why I do complete front crossmember changes to include tie rod, tie rod ends, pitman arm, idler arm and etc. Benifits to changing the entire cross member are, Proper brake line location and tighter turning radius and ease of remembering what you have for future parts replacement. I also use the entire power brake assembly, from the rod to the proportioning valve for the same reasons. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 12-24-2003, 07:19 PM   #6
drink2mny
drink2mny's Avatar
Man you got me all excited to answer rear disc brake questions
Blackbird's
Support The Board
drink2mny is offline   Reply With Quote
