Old 07-21-2021, 02:08 PM   #1
gt40racing
gt40racing's Avatar
Master Cylinder Manual Disc Brakes
Greetings! I am going with 4 wheel disc brakes on my 1970 C10. I currently have manual brakes. What master cylinder is everyone using to run manual disc brakes? Thanks.... I am in the research phase....
1989 5.0 LX Coupe
1989 Saleen #243
1969 C-10 Fleetside
1966 Mustang Coupe GT
1965 Fastback Mustang
1951 F1 Truck
gt40racing is offline   Reply With Quote
Old 07-21-2021, 03:51 PM   #2
Sheepdip
Sheepdip's Avatar
Re: Master Cylinder Manual Disc Brakes
You are way ahead to buy a complete engineered kit from someone like Wilwood
https://www.wilwood.com/
Sheepdip is offline   Reply With Quote
Old 07-21-2021, 07:02 PM   #3
jessemthompson
Most guys run a 70’s corvette master cylinder. Make sure to get one for manual brakes. They are inexpensive and work well.
jessemthompson is offline   Reply With Quote
Old 07-22-2021, 08:46 AM   #4
gt40racing
gt40racing's Avatar
I ordered a 1.0 Bore master cylinder from a 84 C10 with manual brakes. Also ordered an adjustable prop valve. Going to trying this route before I buy a complete system. I do have Wilwood on my 65 Fastback.... easy to go crazy with their solutions....
1989 5.0 LX Coupe
1989 Saleen #243
1969 C-10 Fleetside
1951 F1 Truck
Old 07-22-2021, 08:53 AM   #5
gt40racing
gt40racing's Avatar
https://www.speedwaymotors.com/the-t...allation/29302
1989 5.0 LX Coupe
1989 Saleen #243
1969 C-10 Fleetside
1951 F1 Truck
Old 07-22-2021, 09:37 AM   #6
Bad70sbchevy
Bad70sbchevy's Avatar
Just be sure to make sure you have the correct cylinder bore diameter for the calipers you are installing. That is the key for running manual disk brakes (too big of a diameter, leg day every day and if too small, not enough throw in the peddle to fully engage brake calipers). I'm doing the Wilwood route currently and they had to size that for me. Since you already bought it, I'd definitely see where that 1" bore puts you.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 07-22-2021, 11:53 AM   #7
gt40racing
gt40racing's Avatar
My plan was rather simple.... use Wilwood D52 Front Caliper Kit. For the back I was going to use stock D52 style calipers..
1989 5.0 LX Coupe
1989 Saleen #243
1969 C-10 Fleetside
1951 F1 Truck
