Old 12-24-2003, 01:06 AM   #1
big_c_snow
Carb question... please help me
Hey all, I have a quick question.. how do you correctly tune a 1986 Quadrajet on a 305? I ask this because my truck is running very rich and has trouble with cold starts, and I wish to correct this before I sell it. So, the question is, how do I correctly tune that carb? Is there some sort of special tool I need, or can I do it with a normal screwdriver? How far out do I turn the screws? Thanks!
94 Ford Aerostar AWD
Which is useless in Florida...
86 FJ1200
Daily Driver
big_c_snow is offline   Reply With Quote
Old 12-24-2003, 09:54 AM   #2
85 K5
These carbs don't necessarily get out of tune, they get dirty. If you are willing get the Doug Roe book on Qjets and a rebuild kit. Take your time and all will go well, it's not that hard.
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock
http://www.oplnk.net/~spirit/K5front.jpg
85 K5 is offline   Reply With Quote
Old 12-24-2003, 12:58 PM   #3
Grim Reaper
Uggg 86 is heavy emmisions.
86 uses electric choke AND a mixture solonoid. The mix solonoid adjust by using a thermostat in the intake. It vaires the gound and that changes the speed it osilates and the fuel mixture.
First thing to do is make sure your getting power to the choke once the engine is started. No power then this is a electrical problem before the carb. Check fuse and check that everything is plugged in. The wire from the choke will go to a oilpressure switch that is either behind the distriubutor or above the oil filter. This is to prevent the choke from cycling if the engine is not running.
If you have power at the choke follow the wire over to the top of the carb where it plugs into the mixtures solonoid. The second wire coming out of that will go to the thermostat on the intake. If you have a meter that will measure amps see what that groundwire has on it. No meter take a test light hooked to ground. Probe the wire while everything is plugged up. If the light comes on then the thermostat is probably good.
Unplug the wire from the thermostat and probe the wire going to the solonoid. If the light comes on the solonoid is probably good.
Next wouldbe to check choke function. Fire it up cold and watch the choke and make sure it opens fully after about 5 minutes if it's about 32f outside.
Let us know what you find.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 12-24-2003, 01:15 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
its not so easy to rebuild the kits cost $50 andive tried once and gave it to someone else to go over they were a real mechanic
unfortunately new rebuilts go for $$$ id say look for a junkyard one in good shape
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-24-2003, 01:53 PM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
There was no idle mixture solenoids in any of our trucks. Only thing they had different than other Q-jets was the dual capacity accelerator pump system. A 86 Q-jet was no different than a 85. The tuning is done the same way you would do it on any other year. But, it must be up to operating temp so the pump will be single capacity and not dual. One thing to check is make sure the wire to the sensor at the thermostat housing is hooked up. This is what controls the dual capacity pump solenoid.
I agree on a rebuild. Q-jets don't go out of tune, unless someone has messed with them before and got it all out of wack. 99% of the time when a Q-jet is running rich, for no apparent reason, it's just dirty and needs a good cleaning and rebuild. The float needle wears out and won't shut the fuel off properly.
Rebuild kits are not expensive. Advance sells them for around 25 bucks. But, use regular carb dip to clean them. The spray stuff or gas won't do the job.
Rebuilding a Q-jet is a snap. Everyone thinks they are hard, but they're really easy. Another thing to check for is worn throttle shafts. If this is the case, which happens a lot on these trucks, it will need to be rebushed.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 12-24-2003, 01:57 PM   #6
79Chevypickup
MY TRUCK IS FOR SALE!!
79Chevypickup's Avatar
This site might help....
http://www.carcraft.com/howto/57178/
adjust the mixture screws 2 1/2 turns then start her up,allow to warm up and lower idle speed to 650rpm out of gear,turn one mixture screw in until the engine stumbles then slowly turn the screw out until you have the highest smoothest rpm,repeat the procedure with the other screw,then fine tune by going in or out with both screws until she is steady and smooth,chock the front wheels,set the emergency brake then place her in gear then from THE SIDE OF THE VEHICLE NOT FROM THE FRONT adjust the screws until the idle is very smooth,then adjust idle speed to 650rpm in drive and that is all.shur her off and install the airfilter then test drive
1979 Chevy LWB
350ci / 700R4
Edelbrock under the hood
F O R S A L E OR T R A D E
79Chevypickup is offline   Reply With Quote
Old 12-28-2003, 03:20 AM   #7
big_c_snow
Ok, new problem.... my truck now doesnt like to go over about 45 unless I floor it. And it wint drive around right at simple cruising speed... I hope it's the carb that needs tuned, cuz thats an easy fix. Otherwise..... anyone wanna buy a truck? I need the types of fixes that I can do for free, it's either that or I could probably trade a Bronco 2 for a 327 thats in a cousin's yard that hasnt run in 2 years, but is known to run well. Anyways, please help me, because I think htat this is the root cause of my bad gas mileage. Thanks!
86 FJ1200
Daily Driver
Old 01-04-2004, 01:52 AM   #8
RodKnockin
Well I went though the same exact thing with my 86 , and I'm here to tell ya the problem your having can only be fixed by rebuilding it. I have a friend that has been rebuilding only carbs for 15 years, and he's built them all. he tried to adjust it, but no luck. coulb be something simple. but I doubt it. he told me that a Quad needs a new float every 5 years weather you think it needs it or not. He said they get saturated with fuel, don't work right. they allow extra gas to get dumped in the carb (sometimes). he rebuilt it for me and it works great.
Quads are the best carbs ever madefor daily driving, there the most efficient ones out there.
RodKnockin is offline   Reply With Quote
