Old 07-22-2021, 10:51 AM   #1
Grumpy old man
Grumpy old man's Avatar
Altman easy latch / door repair / gasket install for no slam doors
I have a nice set of rust free doors for my 67 but the drivers door has damage to the door latch mount hole , So I decided to order the Altman latches today from Summit and fix a couple problems with an upgraded latch .and use the gasket install tips from Stout Customs on youtube . I usually get over night shipping from Summit so I'll add a few more install pictures over the weekend . Watch the video . With free shipping Summit has the best prices on these
https://www.summitracing.com/parts/tfg-ael-ct6772
https://www.youtube.com/watch?v=Zvw5RhbhPVc
https://www.youtube.com/watch?v=W_POFylRo8c
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-22-2021, 11:12 AM   #2
dagnabbitt
dagnabbitt's Avatar
Re: Altman easy latch / door repair / gasket install for no slam doors
I'm in, I have always been interested in these.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 07-22-2021, 11:20 AM   #3
darkhorse970
darkhorse970's Avatar
I’m interested to see the results.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 07-22-2021, 12:23 PM   #4
fatbass
fatbass's Avatar
They look sharp...
Go to gringoloco's thread in builds, "How to ruin a perfectly good C10", Page 92.
BTW, his entire truck is amazing.
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 07-23-2021, 08:18 AM   #5
Grumpy old man
Originally Posted by fatbass View Post
They look sharp...
After I considered the cost of new stock style latches and the time to repair the damage to the stock mounting hole upgrading the latches seemed like the way to go . This picture shows they "disappear" after being painted .
Old 07-23-2021, 08:35 AM   #6
Moore87
You may want to check the part numbers. When I bought mine, the summit kit was for shaved door handles. The kit for stock door handles was like $50 more I think
I have them on the shelf ready to install so I’ll be following along
Moore87 is offline   Reply With Quote
Old 07-23-2021, 08:46 AM   #7
Grumpy old man
I saw that when I was doing my research on them , This "kit" is the right one to keep stock handles and locks . They will be here today so I'll post pictures when they arrive just to be sure . Here is the description from Summit , With tax they were $315.00 shipped .
Trique Manufacturing Altman Easy Latch Kits
Trique Manufacturing Altman Easy Latch kits make your door operation as smooth as your classic's looks. Over the years, door latch mechanisms take a real beating. These kits restore safe, secure action with their vehicle-specific, bear jaw-style latch system. And, you get to keep your existing inside and outside door handles, as well as your outside lock cylinder. Altman kits require no welding and include everything you need for both doors. So, if you find yourself slamming your doors to shut them, yanking on them to open them, or, even worse, they're flying open while you're going down the road, it's time for Trique Manufacturing Altman Easy Latch kits. They're built just like your classic ... to last!
Features include:
* Case-hardened steel latch paws
* Stainless steel striker pins and internal springs
* 2-position catch system
* Latch body and levers are zinc plated to provide corrosion protection
* Internal paws are black oxide coated to resist abrasion
Old 07-23-2021, 11:37 AM   #8
Moore87
Perfect. You are on top of it
I agree, the biggest pet peeve I have in mine is the door slamming. I will do whatever it takes to make them close easily even if I have to chop the door/jam area to reduce the weatherstripping compression
Old 07-23-2021, 11:51 AM   #9
Davidf
Many times, hard door closing is due to the position of the door in the cab opening. Much less to do with the latch or the pinch weld that holds the door seal. It can be related to a specific door seal, but not so much.
Many times the door is positioned in the opening to fit the fender position or a poorly fit outer rocker panel. What should happen is the door properly positioned first so that the space between the inner door skin and the seal pinch weld is consistent and sufficient all around the perimeter of the door. Then the fender adjusted to fit the door.
This usually will result in a easy closing door.
Davidf is offline   Reply With Quote
Old 07-23-2021, 12:18 PM   #10
Willys_MB
Willys_MB's Avatar
I'm very interested. I'm tired of my passenger door flying open when I'm going down the road, but don't really like the idea of putting the same thing back in there. Thanks for sharing, Grumpy!
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 07-23-2021, 01:19 PM   #11
Grumpy old man
Summit's speedy delivery . Overnite to here from GA . These latches are for using your outside door handles and door locks as advertised . and I ordered the push on precision gaskets with them . Bye bye door problems .
Old 07-23-2021, 09:07 PM   #12
Zeroman
Zeroman's Avatar
I love my Trique Manufacturing Altman latches.
If you have any issues on the install be sure to give Trique a call. They were extremely helpful when I had questions.
All these doors are just a bit different so you may have to improvise a bit.
I upgraded to the billet aluminum striker plates(second pic) because my "Leroy" deserves the best.
Also, once you get them installed you can get a pair of door prop rods(third pic) to use during shows. You have to bend them to change the radius as they are designed for shorter street rod doors.
https://watsons-streetworks.com/prod...door-prop-rod/
Zeroman is offline   Reply With Quote
Old 07-24-2021, 08:27 AM   #13
Grumpy old man
I'll be ordering the upgrade aluminum striker plates today , The plain steel plate leaves some to be desired . I think I'm also going to add a filler plate to smooth that gap once I check clearance
Old 07-24-2021, 10:49 AM   #14
Moore87
Are you bolting them on or cutting the door and welding?
Old 07-24-2021, 12:01 PM   #15
67swb72klb
67swb72klb's Avatar
It does not look like it would be a problem to flush weld the kit in...
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 07-25-2021, 06:41 AM   #16
Grumpy old man
I bolted them in . Like the pictures above ^ I'll add more pictures later today .
I considered welding them in but given the limited space in the edge of the door and I don't have a tig welder cleaning up mig welds didn't look like it would be fun or fast .
Old 07-25-2021, 07:22 AM   #17
Zeroman
Zeroman's Avatar
The issue you create if you weld them in is that the latch tolerances are designed for the unit to be bolted in.
I believe Trique advises not to weld them in.
If you weld them in they may not work properly, and you may not be able to roll down the window completely as you are effectively moving the latch forward in the door which may impede on the window tracking down into the door.
Also, there is less ability to adjust the latch if you need to.
These trucks were not really precision built vehicles like modern vehicles. There are many tolerance differences between manufacturing plants, etc.
Just try to fit two different doors from two different trucks to a totally different cab, and you will see what I mean.
Old 07-25-2021, 07:32 PM   #18
MONTE
MONTE's Avatar
Might have to give them a try on my c10 suburban!
MONTE is offline   Reply With Quote
Old 07-26-2021, 08:55 AM   #19
Moore87
I have a set on the shelf. Directions say you can do either. There’s plenty of adjustments to allow for it to be welded
I just haven’t decided whether I like all those bolt heads or not
Old 07-26-2021, 09:07 AM   #20
Zeroman
Zeroman's Avatar
Moore87..that's good to know.
I bought very early after the initial release, so at that time they had not included that info.
Old 07-26-2021, 09:27 AM   #21
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I installed these in my doors. When I was test fitting it all together I had the Civic door seals and the doors shut real nice. When it came out of paint we installed the press on Precision seals and the doors require the same old slamming. I thought I would give the seals some time to work in and see if they get better. They may have a little bit but not much. If I adjust the latches "out" a little the doors work fantastic both in and out but the door gap is then terrible. If you adjust to pull the door in flush then they are hard to close and open. Would I buy these again? Yes. They are clean and are easier to adjust over the stock set up.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 07-26-2021, 09:30 AM   #22
Willys_MB
Willys_MB's Avatar
That's a solid review - thanks for sharing.
Old 07-26-2021, 10:14 AM   #23
Grumpy old man
They are really easy to install , I just used a cut off wheel and an angle grinder to clean up the hole ,Clamped it in place per directions and drilled for mounting bolts. easy peasy .
You have to bend the door lock rod and the door latch rods, Again easy and they send a diagram to show the bends ,
Per the instructions they include a new door lock pawl and actuating rod clips for both doors but they didn't come in my kit . So a quick call to Trique this morning I was told there was a shipping error and they would ship them out to me directly and they had already notified Summit and had sent them the missing pieces for anyone who had already ordered . No big deal at least they are sending them .
I just noticed there is some flash rust on the door mount just from over night so I'll pull them back off this morning and get them epoxy primed .
If you have a door like mine with a damaged mount this is an easy way to fix it and upgrade your locks .
Old 07-26-2021, 07:42 PM   #24
72Teeroy
Thumbs up Re: Altman easy latch / door repair / gasket install for no slam doors
Leroy sure looks nice love that door prop pretty dang cool
72Teeroy is offline   Reply With Quote
Old 07-31-2021, 07:45 AM   #25
Grumpy old man
Well ... It took a few days and a number of calls and emails to straighten out the missing parts issue. First Summit was going to send them 5-7 days , Then Trique was sending them , Then Summit sent me an email that the parts weren't available separately so I needed to return the whole kit for a replacement but I had already epoxy primed the mounting plates so finally Trique sent them UPS at my cost for shipping $15.58 So other than that fiasco it's a nice kit and I'll get the doors and gaskets squared away shortly . Here is a picture of the missing door lock pawls and door latch and door lock rod clips .
