Old 12-24-2003, 03:45 AM   #1
Destructo
Do 67-72 front axles fit 73-87?
Will the front axles from 67-72 trucks fit under 73-87 trucks without modification or do the spring perches need to be moved or something?
Destructo is offline   Reply With Quote
Old 12-24-2003, 03:58 AM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
Should bolt right up. There may be an issue about brake hoses on metric vs sae threads. but I am not sure on that one.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 12-24-2003, 11:45 AM   #3
ljbear
ljbear's Avatar
The axle tubes on the later trucks are slightly larger, so make sure you have the correct U-bolts. I don't recall the dimension or what year they changed, someone with a larger hardrive can answer that.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 12-24-2003, 04:43 PM   #4
Destructo
Re: Do 67-72 front axles fit 73-87?
I'd use the calipers off my old axles...
Old 12-24-2003, 05:17 PM   #5
mnick
I have a matching set of 73 1/2 ton axles for sale
they're 4.10 geared and a posi rear if your interested.
I'd take $200 for the pair. I also have a 3 speed trans
and part time transfer case for 50 bucks
mnick is offline   Reply With Quote
Old 12-24-2003, 06:01 PM   #6
HeavyK20
HeavyK20's Avatar
The spring perches are the same for all the years you are asking about. I'm not sure about the tube diameter though.
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 12-25-2003, 02:07 AM   #7
Destructo
Originally posted by ChevyGuyBC
one question...... why unless you like weak diffs that will probally brake plus they are tough to find parts for...
I'm only planning on running 33-35" tires and I can beef up a D44 enough to handle those size tires just fine, D44 axles have more aftermarket than a corp. 10 bolt. I'd like to keep 1/2 ton running gear if I can just because it will save some trouble of changing stuff over to 3/4 ton. I won't be getting a D60 anytime soon anyway so I wouldn't be running anything stronger than a 44 with most likely a 12 bolt rear with lockright lockers.
Old 12-25-2003, 02:09 AM   #8
Destructo
I assume gov-loc 12 bolt rear with D44 front? I may be interested but am not sure when I could get them. Its quite a drive for me to Ohio, and i'm not sure when I could make the drive.
Old 12-25-2003, 02:34 AM   #9
Destructo
I don't need to beef it up to handle 33's but they were just saying its easier to get aftermarket parts to beef them up if I were to go up in tire size.
Old 12-28-2003, 10:37 PM   #10
DaHateTank
the later model D44s (73& up??) DO have bigger axle joints than the old stuff...
That said, I haven't broken anything yet with my 36s, either. But I do replace axle joints, every now and again, if I have the thing apart.
-Marty
PS: 73 12 bolt should not be half-ass gov-lock unit. Should be clutch type limited slip, or open.
DaHateTank is offline   Reply With Quote
Old 12-28-2003, 10:52 PM   #11
Destructo
I have a 12 bolt and 10 bolt front from a 79 right now, 12 bolt has stupid gov-loc and I need a open carrier so I can put a lunchbox locker in.
Old 12-29-2003, 03:30 AM   #12
Cethern
What was I thinking??
Cethern's Avatar
well...
I have a 72 K5 and have had a 83 K5. The first problem I see is the shock mounts are different my 72 has both shocks on the front of the axel, Not the 83
I'm willing to bet the spring pads would have to be moved, I say this becuase I got a Dana 60 out of a 72 or maybe a 70 Blazer and had to move the pads.
The reason I when with a Dana 60 is the old 12b had died, But the thing with the 12b is someone had put it in and when they did it they put blocks on top of the pads for springs to line up on I asked Stephen Watson at ORD about it and the answer was the older chevys had the pad in more than the later yr chevys.
But other than those things it will bolt right in :p If you like I have a 12b out of a 73 I could get the spacing for you if like. I could very well be wrong.
Cethern
Cethern is offline   Reply With Quote
Old 12-29-2003, 03:47 AM   #13
earl87gta
earl87gta's Avatar
I have a 12bolt and a d44 like you need I live in greenville NC dont know how far that is from you but thier for sale if your interested cant remember what gears thow have to look pm me if you think you may want them.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
