Old 07-27-2021, 08:05 AM   #1
Paul Y
Calipers - What have I got?
The joys of assembling parts many years after purchase....
I have upgraded to disks on good old Woody and last night was assembling the campers and attaching the flex lines.
Drivers side, not a problem but the passenger side the thread for the flex line is damaged - it actually looks like a manufacturing fault. Tried running a tap down it but it still is not a good fit.
So, want to get a replacement caliper my question is what caliper do I have.
Done the usual research - there was a thread on it on this site - but no definitive answer.
The casting numbers are
K18007153 GM
but the various sites I have looked on don't recognise it and want to know what vehicle they are for.
I 'think' this is a 79-96 c1500 caliper but, getting stuff shipped over to the UK, I want to make sure as it is an expensive mistake.
Does anyone have a definitive?
Appreciate the help.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 07-27-2021, 08:21 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Calipers - What have I got?
Hard to find. This place shows a 1984 C20.
ER472K Front Left
Absco Disc Brake Caliper ER472K
Disc Brake Caliper
Notes:
Using ABSCO disc reference no: D52 WITH CALIPER CASTING #(S) K18007152 K18007153 REMAN SEMI-LOADED CALIPER
https://dpars.com/fr/Catalog/1984/Ch...-Brake-Caliper
Old 07-27-2021, 08:26 AM   #3
Paul Y
Thanks Chief!
I would have thought that using the part number would have made this an easy find but, alas, not so.
Appreciate the link, will have a look now.
There is still a long way to go before I am back on the road but like to completely finish a job, torqued up and split pins etc, before moving into the next thing.
Should have an update to my thread in the near future.
P.
Woody's Build -
Old 07-27-2021, 09:49 AM   #4
The Rocknrod
Moderator
I think D52 Calipers are from 1971 to 1987 all the same. I think...
Old 07-27-2021, 10:08 AM   #5
Paul Y
Thanks again Chief - it is the D52 part that has opened Pandoras box and I now have a plethora of options.
Has anybody used the Wilwood D52 dual piston calipers and did they fit with a 15" wheel??
Well, If I have to spend money on getting them shipped over I might as well upgrade. Right....
P.
Woody's Build -
