![]() Join Date: Aug 2001
Something went pop and now no 4wd. Help~!
I took my boy up a trail last night in my truck and it went up fine in 4wd. When we got to the top there is about 1 of pavement to the next trail. We were driving about 40 mph when all of a sudden we heard a pop. Then when we got to the next trail no 4wd just the back 2 turning. Any idea what happened? I looked underneath but can't see anything. Where do I start?
Lot's of options here, so let's start with the simple. Could it have simply popped out of 4x? The older trucks are prone to this happening as the detents and linkages get worn. Is there any noise from the front end now when driving?
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
Careful, they attack...
Possible broken chain in xfer case? That would be my guess. It was probably stretched to begin with, and the strain of driving on pavement (turning corners or curves on roads = different speeds from front to back) made it give out. While on dirt, the traction differential can be overcome by slipping wheels, but it's much harder on pavement. Driving in 4WD on pavement is very hard on xfer cases in these older trucks. But also, do like was mentioned above, check the linkages and detents. Good luck, hope it's not too $$$ to fix.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I would check the front hub's to see if they are still intact.. If you have a chain in your case then it's not the 205 and a newer case.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Robert Olson Transport
![]() Join Date: Oct 2002
i am betting on a transfer case chain too
NP 205 Transfer case
I have shifted into 4low or 4high and no result. Transfer case seem to be shifting i.e. you can hear the gears engage. The front lock outs turn and click fine. If the transfer case is working could it be in the front differential? Last edited by Brewski*; 12-24-2003 at 01:51 PM. |
PROJECT 7DEUCE
Maybe the low /high 4wd pill fell out?? Have you checked the linkage rod's to make sure they are still attached to the shift lever??
![]() Join Date: Jul 2003
I am willing to bet it maybe a broken front axle shaft. It happend to me before. This would still let you drive in 2wd but not 4wd.
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
Have someone look under your truck and see if your front driveshaft is turning. This should tell you if its a transfer case or front end problem.
user # 2756
![]() Join Date: Jun 2001
I bet it's an outer axle shaft (stub).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
"Ochre Ogre"
Broken axle shaft. With the open differential the broken shaft would spin the easiest so you wouldn't have any 4 wheel drive since it isn't connected to the wheel anymore.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
I would put the truck up on 4 jack stands on a very level surface, then turn the truck on and put it in drive or 1st. Do not get underneath it but get low enough to see if the front drive shaft is turning. If it is then something in your axle is broken, if not then you should find out what is broken with the transfer case.
#13 |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Brewski, I'll trade you a couple of axle shafts for that Hodaka
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
#14 |
Brewski, I'll bet this is related to your steering problem. My guess is that the knuckle finally locked up and snapped something. When you fix this, you'll have fixed your steering problem. Good luck.
RLTW 70C10 72K10 72K10 Cheyenne 72C10 Cheyenne Super |
#15 |
Next!
Broken axle shaft. When mine broke also spun the timing chain, thank God I didn't turn the truck off til I limped home. Happened while plowing and hit a bare spot. Needless to say I now only plow my own and my neighbor's drive and the firehouse with a 32 year old truck.
Start by doing what EJ says. Good Luck
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
#16 |
Thanks for all the help at least I know where to star... And Beery Christmas to all.
Brew |
