Hubcap Red
I'm sure it's been asked before, but not in a long time...has anyone found a close match to the original red color of the stock caps in a spray can?
![]() Join Date: Aug 2010
Re: Hubcap Red
Re: Hubcap Red
Great thanks. Close enough for me.
#4 | |
![]() ![]() Join Date: Apr 2012
Re: Hubcap Red
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Re: Hubcap Red
If you hate taping and painting, these are done in a very close orange red. https://www.ebay.com/itm/16433349549...MAAOSwAaJaMWME
#6 | |
Re: Hubcap Red
If I do repaint those centers, I use shop made masking dies, which are simple/crude forms made by spreading body filler over a straight cap (which has first been coated with a release agent). The hardened filler is then removed and cut/shaped to cover what should not be painted. One piece covers roughly a three inch ring surrounding the center circle, and another tiny bit covers the center bowtie. Pop them on, spray the red, pull them off and the paint looks EXACTLY like factory. The little center bowtie cover is so small, it needs a piece of sticky tape on the back to keep it in place when spraying. I'll see if I can find a photo. Last edited by oem4me; 08-02-2021 at 01:20 AM. |
