Location: 3,018 feet above the SoCal/Mojave Desert region.
Help with kick panel section.
Needing this section circled in red. Mine was rusted through so it needs replacing. It's already been cut off. Is there a patch panel sold?? And who may have it?? Thanks.
Re: Help with kick panel section.
https://gmcpauls.com/Patch_Panels.htm
Kick (Cowl) Panel Lower 132288 1967-72 Chevy & GMC truck, Suburban, Panel, Blazer, Jimmy, 11"L x 9"H lower footwell kick panel. Specify Left or Right in shopping cart. |
![]() Join Date: Mar 2012
I recommend that you a look at MAY70's you tube Vids he is making and posting while doing the sheet metal repair and replacements on my cab and his
Good info and tips
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
I bought mine at Southwest Classics in Arlington Tx.
https://swclassics.com/1967-72-chevy...ot-well-lh-ea/ |
![]() Join Date: Dec 2009
I think it is a common problem with all on the passenger side.
I had to tweek the bottom to get it to fit. This is also common with most repops though. ![]() ..
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
I dont think I have a video on the inner kick panel yet but ill put one up on the next one I do. Ive got some pictures out of my phone if it helps.
I had to add ~1" to make it fit. I havent had a chance to clean that one up yet but you get the drift. The red circle is really the only reason to buy the replacement panel. If you want to/have the skills to make that rolled edge you could easily make it yourself. I had to manipulate it anyway to match the factory edge. I replaced the whole floor pan in that truck so that's the last step.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
Here is another example where the right curve is the only thing I used of the patch panel.
I had one on hand so I just cut it off, If I didnt have them already I would make it vs buying it. A 4x8 sheet of 18 ga is ~60 bucks
| Bookmarks |
