Old 07-30-2021, 03:33 PM   #1
930chef
door checks
im closing in on finishing a year and a half project restoring a 1966 stepside.
i learned the hard way that a large percentage of parts from all the vendors dont fit and need modifications to fit properly.
what i cant find are a set of door checks that work. ive installed 2 sets from a couple of the large companies, and they are all the same, both sets failed without it leaving the shop.
can anyone offer advice where i can find some sturdy door checks.
thanks in advance
kevin
930chef is offline   Reply With Quote
Old 07-30-2021, 03:53 PM   #2
Justin71105
Re: door checks
Probably going to do the Jeep Cherokee ones on mime, like I found here.
http://www.persh.org/pickup/DoorChecks.htm
http://67-72chevytrucks.com/vboard/s...d.php?t=765556
1964 C10 Rusto-mod
5.3L - L59
Justin71105 is offline   Reply With Quote
Old 07-30-2021, 04:27 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: door checks
Ya I changed to the Jeep units as the aftermarket units kept failing, get stuck etc.
Old 07-30-2021, 07:16 PM   #4
nsb29
nsb29's Avatar
Re: door checks
I did the jeep stops works great
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 07-30-2021, 08:53 PM   #5
bigmoe
bigmoe's Avatar
Re: door checks
I used the Jeep ones as well. I split the rubber in half so the door opens a bit further. There's room to open a bit more but it's working okay.
I've also noticed many modern cars use a similar design in various lengths and I wonder if there's one out there that will work for our trucks.
bigmoe is offline   Reply With Quote
Old 07-31-2021, 07:18 AM   #6
The Rocknrod
Moderator
Re: door checks
Your right. It could open wider. If I could figure a way to shave off the rubber with some accuracy we'd have a good measurement to go by as far as thickness needed to make it open more. However If I screwed it up it could prove expensive.
Old 07-31-2021, 03:33 PM   #7
930chef
Re: door checks
thanks a million for the great advice.
i ordered new ones from the jeep dealer, driver and passenger.
the wrecking yards around here are very small and didnt have any jeeps.
its worth it though, ive spent $40 for junk from china already.
thanks again, kevin
Old 08-01-2021, 08:26 PM   #8
karlbenz
Re: door checks
Is that any jeep cherokee?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 08-01-2021, 09:52 PM   #9
bigmoe
bigmoe's Avatar
Re: door checks
84-96 Cherokee rear doors. (Not Grand Cherokee)
CORRECTION: I checked my records and I used FRONT door ones not rear. #55235571AB
If you google just the part number you'll find lots of suppliers.
Old 08-01-2021, 09:59 PM   #10
61hawk
61hawk's Avatar
Re: door checks
I used front door.
61hawk is offline   Reply With Quote
Old 08-02-2021, 08:01 AM   #11
The Rocknrod
Moderator
Re: door checks
Here is the previous thread on that - http://67-72chevytrucks.com/vboard/s...d.php?t=446066
Old 08-03-2021, 07:18 PM   #12
930chef
Re: door checks
i ordered new door checks from Jeep, and they have modified them or the parts guy ordered the wrong ones.
they dont look like any of the photos of the old Jeep door checks.
does anyone happen to have a jeep part number so i can order the proper ones.
The junkyards close to me have a very limited supply of wrecks to pick from.
if anyone has a part number, that would be awesome.
thanks again kevin
Old 08-03-2021, 07:48 PM   #13
The Rocknrod
Moderator
Re: door checks
thanks again kevin
See post #11
Old 08-04-2021, 09:22 AM   #14
bigmoe
bigmoe's Avatar
Re: door checks
i ordered new door checks from jeep, and they have modified them or the parts guy ordered the wrong ones.
They dont look like any of the photos of the old jeep door checks.
Does anyone happen to have a jeep part number so i can order the proper ones.
If anyone has a part number, that would be awesome.
Thanks again kevin
#55235571ab I split the rubber in half.
Old 08-06-2021, 02:19 PM   #15
karlbenz
Re: door checks
How hard would it be to remove the lever? I'm thinking if it's doable I could burn out one longer on the plasma table
1965 Chevy C60
Old 08-06-2021, 03:44 PM   #16
The Rocknrod
Moderator
Re: door checks
Its easy, pop the spring pin and it comes apart.
