Old 12-24-2003, 01:44 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Clutch /scattershild help..
I am gonna try to put the motor and tranny in project old school this x-mas break,but need help on a few thing's.. What size flywheel and clutch /pressure plate should I be looking for.. Also what should I do about the clutch linkage do i need a aftermarket clutch fork?? Hs anybody here gone hydrolic instaed of mechanical?? Need some input and idea's.. Any help is greatly appreciated..
Thank's Luke.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-24-2003, 10:36 PM   #2
jhwkns
Registered Cruiser
jhwkns's Avatar
I'd use the stock clutch linkage if possible. Switching to hydraulic can be a real chore. Make sure it's going to clear your exhaust. There might be a problem if you have headers.
Do you have the proper flywheel / starter combo for the scattersheild? It could be a determining factor on which clutch you need
Starters for a manuel trans. usually bolt to the bellhousing instead of the block.
What are you using for a transmission mount?
Chances are a stock clutch will work for you.
Good luck with your project Luke.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 12-25-2003, 01:18 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
Thank's I do not have anything but tranny and scatter shield.. I do have a starter that fit's into the hole of the scatter shild. Stock tranny mount seem's to work fine and I don't have exhaust at all... Thank's for the input..
MEMBER #6377
Project "7DEUCE"
Old 12-25-2003, 01:19 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
Ohh ya I am gonna stay away from the hydro linkage also... Need to dig around for the stock z-bar and other assorted rod's..
MEMBER #6377
Project "7DEUCE"
