08-01-2021, 06:48 PM | #1 |
remove cab or not
I am doing a patina restoration on my 65 c10. I am redoing all the interior and detailing under the hood. I wanted to leave the cab on the frame but I need to install both floor pans and rockers inner and outer. It also needs the cab braces so should I do this on the frame or just pull the cab. I already have the front clip off and am going to strip the interior.
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
08-01-2021, 07:42 PM | #2 |
Post Whore
Re: remove cab or not
Gonna be alot easier if your not having to work around the frame and other parts...if your that close ,it wont be much harder to just pull it
08-01-2021, 10:11 PM | #3 |
I would for sure pull the cab. If you can lay the cab on its back, it makes it easier to do the work, and you're going to want to seal everything up so it doesn't rust.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
08-01-2021, 10:31 PM | #4 |
It will make it easier for you.
You will get a lot better access to places you need to work on. ....
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
08-02-2021, 01:22 AM | #5 |
I wish I had the room when I started my build to remove the cab. I cleaned and painted as well as I could but it would have been a better result removing the cab. Now I have a shop with room to work I am too far along for that.
08-02-2021, 06:47 AM | #6 |
Thanks for the replies. The cab will come off. I may start working on it today after work.
08-05-2021, 09:07 PM | #7 |
Before you start make sure your doors fit good. Then weld the bracing in the cab to keep it from moving. X braces in the doors and braces from side to side. I have seen several cabs that had moved when the cab mount braces rotted and several more that moved when the work started and the cab was not braced.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
08-06-2021, 10:35 AM | #8 | |
Good luck and keep us updated... PS PICS PICS PICS ....
John 3:16 - Saved me... God Bless |
08-06-2021, 10:05 PM | #9 |
I have started a build thread and have some pictures there. I will post more there soon
08-07-2021, 07:13 AM | #10 |
There will always be more patching do do than you think. It may be a good idea to replace body mount bushings while you are at it. Removing the cab will make it easier.
08-07-2021, 07:42 AM | #11 |
Yes I am planning on replacing the bushings.
08-08-2021, 08:10 PM | #12 |
08-09-2021, 08:37 AM | #13 |
Moderator
It's good you did it. Find out what the issues are and get with the rat killin.
08-09-2021, 08:41 AM | #14 |
Funny thing about a rat. A few years ago I had a cab in the shop I got from a old junk yard and was doing rust repair on it. I starting noticing things being chewed and found out a rat was living in the cab. I left the cat in the shop all night but rat was still in the cab. A few days later found it dead in the kick panel vent.
