Old 08-02-2021, 05:50 PM   #1
ChevyGuyNC
ChevyGuyNC's Avatar
Rebuild the carb or not?
I've got a 72 Cheyenne Super, 350/350... 47k original miles, and she runs good, not great...
Recent plugs, wires, coil, points, condenser, rotor, cap, etc...
Adjusted everything with vacuum gauge and timing light. 8* timing, 15" vacuum.... idles nice at 650 or so when warm...
Truck runs really good, but she stumbles when cold, and even when warm there's a hesitation if you goose her.
I poured some Berryman down the carb, and dumped a can in the tank, and that made a difference, but the hesitation is still there.
So, thinking carb needs a rebuild.
Thoughts?
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor
ChevyGuyNC is offline   Reply With Quote
Old 08-02-2021, 06:06 PM   #2
kwmech
Re: Rebuild the carb or not?
Possible small vac leak somewhere. take a 1/2 wrench and see if the bolts holding the carb down will take a little twist....don't over tighten. Accelerator pump could be bad if it is original from '72. New gaskets and a float may help things out. Did you check the vac advance?
Old 08-03-2021, 12:26 PM   #3
Wrenchbender Ret
Sounds like a carb cleanout is in order. Like KW says, the accel. pump is probably bad. The metering rods may be stuck. If you think you are qualified to do it yourself go after it. Don't let just anyone do it though. You don't want it butchered. Of all things don't exchange it for a "reman".
George
Wrenchbender Ret is offline   Reply With Quote
Old 08-03-2021, 12:45 PM   #4
kwmech
George
Absolutely---keep the original carb with the engine
Old 08-03-2021, 01:13 PM   #5
Caddylackn
Caddylackn's Avatar
If you have the factory Quadrajet, get the Cliff Ruggles Quadrajet book. He sells quality rebuilt kits specific for your carb https://cliffshighperformance.com/.
He also has a forum to post up questions (which he will reply to) and view other rebuilds in progress.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 08-03-2021, 01:55 PM   #6
68Gold/white
Posts 3 and 5 are the gospel about carbs!!!!
Is it a Quadrajet carb???
68Gold/white is offline   Reply With Quote
Old 08-03-2021, 01:57 PM   #7
geezer#99
geezer#99's Avatar
A slight stumble can be caused by retarded timing.
A 47000 mile timing chain can stretch enough to reduce your initial timing 4 degrees.
Instead of setting your timing at 8 degrees just bump it up to 12 degrees. After you bump it up adjust your mix screws on the carb and turn the idle back down. You’ll likely gain 2hg of vacuum too.
If you want to check timing chain stretch just pop the distributor cap off and rotate the crank forward and back and watch the rotor movement.
geezer#99 is online now   Reply With Quote
Old 08-03-2021, 03:14 PM   #8
LT7A
Good info being shared here. Makes me think of people who had vehicles that they liked, but just got tired of them never quite running right.
Old 08-03-2021, 08:13 PM   #9
ChevyGuyNC
ChevyGuyNC's Avatar
Yes, Rochester Quadrajet 7042210
Thanks for all the replies. Sent a quote request to Cliff's and been reading through the forum there.
Old 08-03-2021, 08:22 PM   #10
MikeB
MikeB's Avatar
Good idea on 12 degrees initial advance. Yes, vacuum on a stock engine should be more. I'd say at least 18", even for an engine with more miles than yours. You may have a leak somewhere.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 08-03-2021, 08:23 PM   #11
dmjlambert
dmjlambert's Avatar
Did you replaced the fuel filter? There is a holder for the filter in the carburetor front inlet and there should be a spring behind the filter. Be careful not to cross thread or over tighten the inlet.
dmjlambert is offline   Reply With Quote
Old 08-03-2021, 08:24 PM   #12
MikeB
MikeB's Avatar
Originally Posted by Caddylackn View Post
If you have the factory Quadrajet, get the Cliff Ruggles Quadrajet book. He sells quality rebuilt kits specific for your carb.
Excellent advice!
Mike
Old 08-03-2021, 08:27 PM   #13
ChevyGuyNC
ChevyGuyNC's Avatar
I'll give the timing a shot. I could be wrong on the vacuum; my memory isn't what it used to be. I'll check it again tomorrow.
Old 08-03-2021, 08:33 PM   #14
ChevyGuyNC
ChevyGuyNC's Avatar
Yes, new filter.
Interesting anecdote about the filter. A friend I met who has lots of experience with carbs mentioned that he always takes the paper filter out and uses an inline filter. He said the paper ones aren't made for today's gas and they get clogged easily.
Old 08-03-2021, 09:00 PM   #15
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I think that the reason the paper filters fail is because the new fuel has alcohol, which loves water, and the paper filters don't.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 08-03-2021, 09:14 PM   #16
chevmn
No one has mentioned, but one of the biggest issues with Quadrajets is the float. I learned this the hard way years ago when I tore one down several times, and finally took it to a guy and asked him to rebuild it. The next day he had it done, and told me the float was saturated (he weighed them), so he replaced with a brass float. I always buy kits with brass floats now, and no more issues with floats. If your has the "fiber" type float, and it has been in there a while, my bet is it is heavy and or sunk. Also check primary throttle shaft for play.
chevmn is offline   Reply With Quote
Old 08-04-2021, 10:22 AM   #17
ChevyGuyNC
ChevyGuyNC's Avatar
Talked to Cliff, and ordered a kit plus a choke pull off.
What a great knowledgeable guy.
Thanks for all the tips!
