Old 08-05-2021, 03:07 PM   #1
don t. - 72gmc
Brake booster differences
R&R of entire brake system on a 1970 GMC 2500
While I expected it to be a bit different, the length of the rod to the interior pedal on the new looks short.
Ideas appreciated.
Thanks much...don t.
don t. - 72gmc is offline   Reply With Quote
Old 08-05-2021, 04:19 PM   #2
BigBird05
Re: Brake booster differences
That booster just doesn't look right for a 72.
BigBird05 is offline   Reply With Quote
Old 08-05-2021, 11:07 PM   #3
jimijam00
Isn't it adjustable? Most aftermarket jobbies are.
jimijam00 is offline   Reply With Quote
Old 08-05-2021, 11:32 PM   #4
Bob B.
Looks like a '67-'70 dual diaphragm Bendix. Some '67's are a little different, don't have the reinforcing tabs welded on the back half. These are for 4 wheel drum brakes. Factory disc brake booster/master cylinders are different, and use a different length pushrod. Be careful, using the wrong push rod = no brakes!
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
