Recommend A Quality Headlight Switch ?
Trying not to buy China garbage !
71 C-20 07 Magnum RT AWD |
One of the First
![]() Join Date: Jan 2000
Re: Recommend A Quality Headlight Switch ?
are you referencing the floor foot switch or the dash pull?
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
Standard products i have had good luck with them.
mind you the last light switch I replaced was in the early 90s and my fault for putting high watt high beams with no solenoid to run them |
Dash switch ! I have read that numerous repops are junk.
One of the First
STANDARD
https://www.ebay.com/itm/163247205270 NIEHOFF https://www.ebay.com/itm/23302295735...97.m4902.l9144 ** LINKS WORK NOW
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 08-06-2021 at 02:21 PM. |
Thanks for the lead. I will buy local after seeing what they want for shipping. I located the correct type screws for the headlight rings. $1.98 +$14.95 for shipping via fedx with no other ship option....
