08-06-2021, 07:15 PM | #1 |
Wheel help.
I’m trying to plan my wheel/tire combo.
This will possibly be going on a 71 gmc C1500. It’s got the 5x5 lug pattern and no modifications to the suspension. Eventually I’d like to do a 4/6 drop, add some sway bars and perhaps relocate shock mounts. The wheels I’m considering have the following specs. Size: 15x8 | Bolt Pattern: 5x5 | Offset: -19mm | Center Bore: 83.1mm | Backspacing: 3.75. The tires are not the immediate concern yet. Does anyone see a problem? I did read the 15 inch wheel thread but no post had all of the wheel specs including back space, offset and bore. Thank you. Jeff Last edited by Jeff1971; 08-07-2021 at 12:03 AM. |
08-07-2021, 07:08 AM | #2 |
Re: Wheel help.
id suggest you post this down in the suspension section, lots of info there. my project wouldn't relate to yours but i got a wealth of help in that section
08-07-2021, 11:00 AM | #3 |
Re: Wheel help.
Thanks Bob. I will.
