12 bolt wheel stud????
Any 12 bolt guys out there? Guess I got the wrong replacement studs…. I got Dorman 610-298..,1/2-20. Seems like I need a larger kurl and different thread pattern….. trying figure out what I have…
1989 5.0 LX Coupe 1989 Saleen #243 1969 C-10 Fleetside 1966 Mustang Coupe GT 1965 Fastback Mustang 1951 F1 Truck |
Re: 12 bolt wheel stud????
Go to the parts store and start comparing studs.
I went to the parts store and the kid kept staring at the computer hoping for an answer. I then asked him to let me use the computer. I found what I needed. Of course no one in town stocks it. I went home and checked my solution across a couple references like Summit and Jegs.... ordered two sizes off Amazon. The knurl matches what I current have plus it is 1/2-20. Studs will be here on Tuesday.... cleaned up my axles and removed old studs.... I needed my studs a little longer because of a disc brake conversion on the rear...
Glad you solved your problem. The NAPA store in our town is the best place to find something other than what's listed in the books.
![]() Join Date: Dec 1999
What part numbers did you end up buying?
| Bookmarks |
