k10 big block cooling problems
i have a k10 with a mild built 454 thats having some cooling problems at idle the gauge runs straight up going down the road but if i let it idle it starts to run over on the hot side of the guage i've used a temp gun on the thermostat housing its around 200f when the gauge shows it hot but when shoot around the sending units its 210-215f . this is what i've done so far 7 blade fan gm heavy duty fan clutch repop big block fan shroud new 16 ibs stant rad cap added recovery tank timing is good carb runs alittle rich also it has a wieand aluminum short water pump short and the fan is half in the shroud it has a 4 core radiator that was in the truck when i bought it i really don't want electric fans either
Re: k10 big block cooling problems
nothing wrong with those temps on a big block
Who Changed This?
![]() Join Date: Jan 2013
200 is about where mine runs, now, idling in hot traffic. I ended up putting in a high flow thermostat, and that licked the problem.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 08-08-2021 at 08:59 PM. |
its just not a good feeling to look down a the temp guage is 3/4 to hot i'd try the high flow thermostat is that something special and what temp thermostat did you go with
On chevelles.com website there are multiple articles about cooling a BBC. I was having cooling issues with a 454 in a 67 Camaro. I made some changes outlined in the articles and now I don't have any issues.
The article recommends to use Hayden 2747 fan clutch with a part #3947772 ("772") GM fan. The article claims a 160 degree thermostat from auto zone outflows most and is the one to go with. The only thing I did different from the articles on chevelles.com is a different fan. The fan I went with was a reproduction part #3976064 ("064") 70 LS6 fan. This fan will pull more air at low speed than the "772" fan. Now I don't have any low speed overheating. Hope this helps, Steve |
i just ordered the fan you suggested it does seem to be an airflow issue and i'll try swap the thermostat its been a while since i've drove with out electric fans but i never seem to hear the fan locked in shouldn't it be louder when the engine heats up i even let it set at 1800 rpm for a few minute in the driveway and it made no difference
#8 | |
I purchased a reproduction fan #3976064 from drclassic.com
thats where i ordered mine from to i'm gonna try that and a thermostat swap really don't want to change my fan clutch just yet its a gm heavy duty i bought nos and it was really expensive
#11 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
If you really feel the need to upgrade to a severe duty fan clutch, Hayden lists a few comparisons. https://www.haydenauto.com/en/produc...-types/thermal Heavy Duty Turns the fan 70-90% of the shaft speed when engaged for increased cooling Turns the fan 25-35% of the shaft speed when disengaged Used with deeper pitch fans (2-1/2” of pitch) Land and groove design with up to 27 sq. in. of working surface Identified by finned aluminum faceplate and thermal spring on the front Severe Duty Turns the fan 80-90% of the shaft speed when engaged Turns the fan 20-30% of the shaft speed when disengaged Used with deeper pitch fans (2-1/2” of pitch) Land and groove design with up to 72 sq. in. of working area Larger working surface provides cooler running and longer life expectancy Thicker body and deep finned faceplate dissipates more heat Can be used in place of many heavy-duty clutches
From chevelles.com website:
#12 · Jan 12, 2017 Robinls5 said: Not sure about your year car. The 3947772 Fan blade was designed for the 70-72, 69 ? for the 3:31 Rear end. The 70 LS-6s also used the 772 fan blade with 3:31 Rear. NOW if you ordered the factory 4:10 rear gear, The 3947772 fan blade was replaced with a different number fan blade , I forget that number. Same size, BUT a different pitch on the blade. Its all about moving XXXXX number of Cu. Ft. of air per. Min. through the Heat Exchanger or Rad. Bob 3976064 LS6 with 4:10. Dates M69 and E70. > ![]() |
#13 |
The BBC off the dealer lot needs the same idle and low speed cooling as the next, regardless of diff gear, so the change likely has nothing to do with more cfms at low speeds. Maybe it had something to do with to do with HP savings on those cars with 4:10s because they reved higher and quicker.
#14 |
Who Changed This?
I agree with your cooling assessment, but shouldn't the clutch "free-wheeling" take care of the HP savings? My non-AC '64 Impala with SHP 30 HP 327 was equipped with a fan clutch (no A/C). Though in fairness I should point out that the original purchaser worked at the assembly plant where it was built, and followed it down the assembly line. He probably conned a clutch fan out of the assembly guys. Not an SS, but it got SS wheel covers. He bought it to street race, and did a lot of it.
#15 |
An improper idle mixture can cause overheating at idle. I would fatten up the idle mixture some and see if it improves.
Improper timing can also cause overheating. What is the base timing set at?
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
#16 |
i went out and looked and it has a 772 fan on it now hope the new one helps its run 16 degrees of ignition timing at idle when the vacuum advance is unhooked one thing i'm gonna look at is to see if the vacuum advance is on ported vacuum and change the fan and thermostat and see if that helps also put a mechanical temp gauge on it we'll see what happens
#17 |
just swapped the fan and checked i had the advance hooked into ported vacuum hooked it to manifold vacuum on the carb just above the intake manifold and it seems to run cooler down the road and idle but i just took a short trip i really think it was where i had the advance vacuum going to manifold vacuum that made the difference i'll get it out this weekend and see if its cured thanks to everyone for the help
