Old 12-24-2003, 04:42 PM   #1
doughby82
doughby82's Avatar
heater problems
ok when i bought my truck it never heated up.i figured it was a thermostat.i changed that and the radiator cap.it gets a little warm but that it.also it starts drippiling out of the radiator overflow,when its running and after i shut it off.any ideas
springfield illinois
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
Old 12-24-2003, 05:17 PM   #2
cdowns
cdowns's Avatar
as far as the little or no heat is concerned a couple of things could be that the valve controling flow thru the heater core is not opening up or the phlenum that holds the heater core is filled with debris loke 30years of pine needles or leaves
as far as the water flowing out the overflow don't fill the radiator when it's cold only fill when the motor is up to operating temp
Old 12-24-2003, 05:26 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The radiator problem is something a lot of younger guys don't know about.When the engine and radiator heat up the water/coolant expands overfilling the radiator in effect and causing it to run out the overflow.
The later cars used an overflow tank that let the coolant escape to the tank and then it was returned when the engine cooled and created a vacumm.All engines of the non-return line type will use some coolant.They should be filled on ocassion.
You can retro fit a coolant overflow and return easily, if you use the tank from a truck with one or install an aftermarket one.
New cars are required to have them for EPA, as are race cars to prevent wet spots on the track that cause slick spots.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-24-2003, 07:35 PM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
Yes, like cdowns said, the valve controlling heat flow could not be working (assuming this is a non AC truck).
You can look at the flapper valve from inside the cab....it is where the heater control cable goes into the heater box, under the dash in the passenger side footwell. There is a little plastic piece that seals the rectangular hole where the control cable goes in, pop it out and have a look. Make sure the cable is still attached to the lever on the flapper valve, and that it is opening and closing all the way.
If that checks out, you proably have a heater core plugged with pine needles or something. You need to remove it....and proably replace it too. A new core is only around $25, and as long as it is out it would be a good idea to replace it.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-25-2003, 01:28 PM   #5
nitor
Too many projects
nitor's Avatar
Yellow72 is right. I just had to replace mine. A/C version. Got it at Autozone. It was about $25.
Jim
'55 Chevrolet Pickup
'56 Chevrolet Belair
'04 Chevrolet Astro
'95 Chevrolet Blazer
nitor is offline   Reply With Quote
Old 12-25-2003, 01:36 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Same here I just replaced the core in the blazer and it seem's to blow really hot. I also replaced the fan switch that control's the fan speed .. I never knew there was 3 speed's for the fan..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-25-2003, 05:16 PM   #7
1969 GMC
1969 GMC's Avatar
lol! of course they are 3 speeds! mine is:
1). off
2). on but nothing comes out the vents
3). on and air is blowing like a hurricane
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
