Old 08-10-2021, 02:13 AM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Anyone found a direct fit condenser of late?
Apparently one doesn't exist that's specifically for 134A??? which my original parts were reconditioned for, less the condenser.
From what I've read 134A works best with a parallel condenser as opposed the old tube versions, but apparently it works well enough with a tube condenser for my climate, and I'm not driving this thing anyway
I'd like something that mounts like intended, hoses and that. Thank you....
This might be an option....https://www.ecklers.com/1967-1972-ch...-178426-1.html
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-10-2021, 08:01 AM   #2
cj847
cj847's Avatar
Re: Anyone found a direct fit condenser of late?
What about the condenser and mounts from vintage air sure fit system? I'm not sure exactly what the factory condenser looks like but the VA is pretty close and fits perfect.
cj847 is offline   Reply With Quote
Old 08-10-2021, 08:52 AM   #3
Bigdav160
Bigdav160's Avatar
I had to purchase generic and cut and reweld the tube ends off my old condenser
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-10-2021, 09:30 AM   #4
body bolt
I used a generic condenser with the VA mount. With that I used an 18" #8 VA M-F u-bend-em through the radiator support with a #8 elbow and then made 2 hoses.
body bolt is offline   Reply With Quote
Old 08-10-2021, 10:59 AM   #5
kwmech
Got rid of the POA system and went with a cycling system with a different compressor.
Old 08-10-2021, 12:30 PM   #6
71CHEVYSHORTBED402
Per Old Air products: We do have a oem replacement condenser that has been updated to work with R134A that part number is 11-7201
Tony
Old 08-10-2021, 02:05 PM   #7
body bolt
Cool! I would have used that.
