I have a 1979 Chevy 3/4 ton 4x4 with a sm block . I want to put a 454 in it what do I need and where do I get it.
Thank you for any help |
Your gonna need headers, pulleys, alt brackets, power steering brackets, fuel pump, flywheel or flexplate. If you have a/c then those brackets as well. You can get the pulleys, alt brackets, flywheel or flexplate, headers, and fuel pump from summit racing. The power steering and a/c brackets you can get from GM. The rest is misc.
I guess my main concern is motor mounts. The 454 is in a 2 wheel drive suburban that I'm driving. It dosen't look as though the saddles and mounts are the same. Where would I get these.
You can use your same 4x4 mounts that are in your 79 4x4.
