Old 12-24-2003, 06:04 PM   #1
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
How to ADD a Tach
I want to add a Tach to my truck. But not sure how I would wire it up exactly. Does anyone know of an aftermarket tach that would fit in the middle of the instr cluster panel? It is a standard instr cluster without the tach and only the three other gauges. I would like to "fill the holes" with appropiate gauges. I have never done this before and would like to do it.
'92 GMC Sierra, Sportside, 2wd, 350, Black
'92 Chevy Silverado Extended Cab 4 x 4, Blue
USAFR = 2A674 = Aircraft Fuel Systems Maintenance
i.e. Tank Rat
TsgtE662 is offline   Reply With Quote
Old 12-24-2003, 06:14 PM   #2
rage'nrat638
rage'nrat638's Avatar
here you go....check this tread
http://67-72chevytrucks.com/vboard/s...+new+tach+dash
rage'nrat638 is offline   Reply With Quote
Old 12-24-2003, 06:16 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
More options.......
http://64.246.42.114/vboard/showthre...threadid=82148
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 12-24-2003, 07:10 PM   #4
special70gmc
special70gmc's Avatar
mine auto gage by auto meter -kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 12-24-2003, 07:28 PM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
Its not very hard....just take apart the dash and slice appropiatley
A hole say, jig saw, or a dremel with a cutoff wheel works well.
I have had good luck with sunpro guages....but if you can afford better, get some Autometers
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-24-2003, 10:14 PM   #6
photoglg
photoglg's Avatar
Good question, but how do you wire ti up.
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 12-24-2003, 11:44 PM   #7
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
Aside from finding a tach that would fit and other new gauges to replace the old, how to wire it/them is my main mental challenge with this. I'm not sure on that part. I am kind of Electrically challenged mostly.
i.e. Tank Rat
Old 12-25-2003, 12:02 AM   #8
lukecp
lukecp's Avatar
Wiring it up is dead simple....just follow the directions that come with the tach. Four wires is all it takes....the instructions make it ultra easy.
Black wire-ground (any clean metal surface on the truck)
Green wire-tach feed (TACH terminal on HEI)
Red wire-power, any source that is hot with the ignition is on (IGN UNFUSED terminal in fusebox works great)
White wire-Backlighting wire, i tapped into the wire that lights up the heater controls light bulb.
Very, very easy to do. Only took me 20 minutes or so when i installed it on the steering collumn.
Old 12-25-2003, 01:02 AM   #9
TsgtE662
2A674 Tank Rat
TsgtE662's Avatar
It still has the original points type distributor. Is there a Tach connector on it?
i.e. Tank Rat
Old 12-25-2003, 01:12 AM   #10
rage'nrat638
it's the negative side of the coil...is where the tach hook's up....
i think
go to your local pep boy's the tach 3 3/8 size is 42.00...
follow the instuctions.....if you can type and use the computer you can hook this up.......
Old 12-25-2003, 03:06 PM   #11
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
it IS the neg side of the coil. Just crimp a connector on the end of the wire and stick it on there
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
