engine bogs under load
have an 84c10 with 5.3/4l60e swap DBC
truck bogs down under acceleration. idles fine but will only speed up gradually and falls flat when I step on it. fuel pressure is steady at 58psi things I have changed: MAF Fuel pump fuel regulator throttle body fuel filter complete wiring harness codes that just popped up recently are: p0107 manifold absolute pressure/ barometric pressure circuit low p0342 camshaft position sensor A circuit low bank 1 or signal sensor p0740 torque converter clutch circuit/open p0753 shift solenoid A electrical p0758 shift solenoid B electrical what would you guys check 1st?
| Bookmarks |
