Old 08-15-2021, 01:19 PM   #1
Zachary17
Zachary17's Avatar
1970 gmc half ton disk swap
So I bought a 70 gmc a few days ago and and my plans are to fix it up and drive it.going over the truck I found that the front end is Beyond wore out no brakes.lots of play in everything it’s sat for 15 years.it still has drum brakes on the front I want to convert to disk while I have the front end apart l.I don’t want to use a aftermarket brake kit.I do have brand new hd spindles for a 73/87 c10 and ball joints.can I just use the 73/87 spindles and brakes and ball joints or do I need something else(
Zachary17 is offline   Reply With Quote
Old 08-15-2021, 06:59 PM   #2
Re: 1970 gmc half ton disk swap
You'll need tie rods and the front crossover bar that the inner rods hook too. Sorry I forgot it's name.
Old 08-15-2021, 09:07 PM   #3
67C10Step
67C10Step's Avatar
Drag link. You will need the drag link from a 73-87 as well. I have one if you need it and can’t find one locally.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 08-15-2021, 09:30 PM   #4
Zachary17
Zachary17's Avatar
I have one out of a 79 c20 I don’t know if it’s the same as a half ton.what about the pitman arm and Idler arm do I need them from a 73/87 or just use the factory ones
Old 08-15-2021, 11:23 PM   #5
68Gold/white
Center link..
68Gold/white is offline   Reply With Quote
Old 08-16-2021, 09:24 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Check this thread by lolife99 out. It is in the mini-FAQ at the top of the suspension forum.
LockDoc
Leon
Old 08-16-2021, 11:11 AM   #7
Zachary17
Zachary17's Avatar
LockDoc
Ok that helps a lot thanks
Old 08-16-2021, 11:57 AM   #8
Caddylackn
Caddylackn's Avatar
LockDoc
I wish there were pictures alongside this list so I could determine what type of swap and parts had been installed from the previous owner. Many of us buy trucks with the swap already done and need to know which parts to buy when we "freshen up" the front end and brakes.
Maybe have a new thread/stickie on identifying what parts you have on your swap?
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 08-16-2021, 12:27 PM   #9
Zachary17
Zachary17's Avatar
That’s a good ideal.I think 73/87 have 11/16 tie Rods and 67/70 are 5/8 tie rods
