Any difference between C10 & C20 Rearends?
Follow up to my other post in regards to front end differences. Thanks again for those reponses.
Now I am trying to figure out if there are any differences between a C10 and C20 rearend (other that the bolt pattern in the axle flange and drums) . Trying to convert from 8 lug to 5 lug. I know I can buy the conversion kit that comes with new axles and new drums, but I might have access to a 1970 C10 rearend. So if they are the same I think swapping the rear end might just be the easier. |
Re: Any difference between C10 & C20 Rearends?
Hey there,
A C20 rearend is way different than what is found on a C10. The C20's will have a full floater 8 lug setup, either a Corporate HO52 or Dana 60. As far as I know, there is no aftermarket 5 lug conversion drums, axles, etc. for the axles mentioned above. |
This was one of the kits I was looking at (although looking closer looks like it is for 6lug to 5 lug).
http://https://www.speedwaymotors.co...RoCAOsQAvD_BwE Okay with that said, is that the only option I have to go from 8 lug to 5 lug is to swap the whole rear end? Last edited by D-n-Tyke; 08-15-2021 at 10:25 PM. |
Yes, that is correct. I'm sure you can find a donor 12 bolt diff from a 71-72 C10. Or if that isn't possible, a 6 lug to 5 lug swap (as you referenced) is fairly common.
On a side note, are you switching to 5 lug for wheel selection or for disc brakes? |
#5 | |
Yes, I am looking to switch from 8 lug to 5 kug for both reasons. Want disk breaks and I want to have some options for wheels. Question for after I do this conversion. Are these C20 rearends in much demand? |
I see. That sounds like a nice package deal if he's willing to negotiate.
And there is some value in that rear end, although it's a niche market. Finding good used 8 lug rears of this vintage is getting tough. Does yours have a locker/"No-Spin" unit? |
#7 | |
I am not sure if it has a locker or not (just pick this up a couple weeks ago). Would it be listed on the SPID? I will have to go out and look and see if I can find a tag on the rearend. |
![]() Join Date: Mar 2015
Yes.... However, things may have been switched out over the last 50 years. |
![]() Join Date: Mar 2014
You may be able to get a couple hundred $ for you 8 lug depending on the gear ratio and type but it could be a while before you find a buyer. My friend gave me a Eaton axle off his trailing arm truck and I posted it on Craigslist for free, luckily nobody picked it up because I removed the 4:10 Ring & Pinion and sold it on this website for $375. It sold a couple days after I listed it. Parts are not available for the Eatons so if you have the right gear ratio it can be worth some money.
Made in America by Americans |
I was just barely able to give away a good Eaton 4.56 from a C20. I also sold a C20 Dana 60 3.56 (somewhere around that ratio) for $600.
The Eaton stuff just isn't available, or cheap, so the market is very small. |
I agree with the posters above. Your best bet is to post your old diff in the parts section and see what offers you get, you may be surprised.
Well the front suspension was sold before I could get there. But I did end up picking up the rear end, actually it was the whole back half of the frame (arms and springs) cut just forward of the trailing arm crossmember, and a set of steel wheels and tires. The whole shebang for $300. Figure not a smoking deal but one I could live with.
Now on to the hunt for a front suspension. |
#13 |
Rears go in the $300 range. You did fine. You also have the extra parts to sell. The '70 rear is the last 6-lug but is the same width as the '71-ups. The rears got widened when disc brakes came out. You are all set. So this rear has been converted to 5-lug?
#14 |
#15 |
You did excellent, a good set of trailing arms go for at least $250.
#16 |
That is good to hear. I kept the trailing arms and the trailing arm mounting crossmember (with mounts). Going to junk the rest of the "half" frame as I assume all the other crossmembers are common and not worth anything.
