Old 08-16-2021, 06:25 PM   #1
hdixon
Outer tie rods
I need information on outer tie rods
I have a 69 c10 5 lugs disc brake on all 4 corners I purchase everything from Cpp center link inner / outer tie rods and drop spindle went to have the alignment done today and the alignment shop are saying the outer tie rod are not correct fit for the spindles can anyone share some light as to what I need to do at this point just and fyi I went back and check my invoice from Cpp and it shows the outer tie rods are 63-70 however the spindle is showing 73-87
will this part correct my problem any help would be great
Classic Performance Products Tie Rod Adjusting Sleeve OE Chevrolet C10 1965-1970
Classic Performance Products: ES350S
hdixon is offline   Reply With Quote
Old 08-16-2021, 08:13 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Outer tie rods
If you have 73-87 spindles, the only tie rod that fits will be a 73-87 outer tie rod.
Your other choice is to use 63-70 conversion spindles
Keith
Convert to disc brakes.
Old 08-17-2021, 12:55 PM   #3
lolife99
lolife99's Avatar
Re: Outer tie rods
Answered your Pm also
Keith
Old 08-17-2021, 12:59 PM   #4
lolife99
lolife99's Avatar
Re: Outer tie rods
Here’s the old thread where I figured out this problem first hand, on my truck.
I guess this is the only way you remember stuff.
When you struggle through it yourself.
I’ve been trying to get this info out ever since.
http://67-72chevytrucks.com/vboard/s...d.php?t=328438
Keith
