Old 12-24-2003, 08:25 PM   #1
tricities 65
71 C20 rear end #'s
What numbers on the rear end of a 1971 C20 would indicate a 3:73 ring and pinion ratio? Or where can I find the numbers to cross reference the actual ones one the rear end tube? Any help would be gereatly appreciated. Thanks,
Rick
tricities 65 is offline   Reply With Quote
Old 12-24-2003, 09:02 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
If the cover is taken off the rear, the numbers should be stamped on the ring gear (on a 12 bolt anyway, not sure about a Dana 60 or an HO52).
They would be like 41:10, which would mean 4.10 gears.
Or you could jack the truck in the air, and count how many turns the driveshaft makes from one turn on the wheel. If it was about 4 exactly, you would have 4.10 gears, about 4.5 would be 4.56, ect.
Good luck
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-24-2003, 11:15 PM   #3
Solver
Solver's Avatar
I checked my book and it shows no 3:73 for a c-20 1971
my book lists for 71 C-20:
3:54
4:10
4:56
4:57
It does show a g-20 (whatever that is) as having a 3:73 available
3 letter code for a G-20 3:73 is TPJ
3 letter code for a G-20 3:73 posi TPK
1972 doesn't show a listing for C-20 with 3:73 either
1970 shows a GA-20 (what ever that is ) with 3:73
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 12-24-2003, 11:30 PM   #4
tricities 65
thanks, very helpful!
Old 12-24-2003, 11:33 PM   #5
Duallie
Duallie's Avatar
A G20 is a van. P30 is a 1 ton class A motorhome.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 12-25-2003, 11:28 AM   #6
Mike C
Mike C's Avatar
The Dana rear axles all came with a tag that tells what ratio the axle has. The tag is similar to a 12 bolt limited slip fluid tag, a metal thing that bolts to one of the cover bolts. It will have the ring and pinion numbers (41:10 etc.) stamped on the tag along with a part # for the axle assembly from Dana. UNLESS some past owner changed diff fluid and saw no reason to put it back. Highly irritating...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-25-2003, 11:55 AM   #7
tricities 65
i'm going to look at the truck tomorrow with hopes of buying it. The owner did say the tag was missing. Looks like I'm going to just have to jack it up and spin the wheels! Thanks
