Equal opportunity joke ofender
![]() Join Date: Oct 2011
67 only Dash
Will cut anywhere you want and ship. The edge around the windshield pinch weld is rotten as shown, everything else is good. Includes ash tray.
$125 plus shipping SOLD .
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. Last edited by richard2717; 03-17-2022 at 04:01 PM. |
Re: 67 only Dash
I will cut out center section for $125 shipped as well
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
Re: 67 only Dash
ttt
Junior Member
![]() Join Date: Feb 2022
Re: 67 only Dash
Is this dash still available?
Re: 67 only Dash
Junior Member
Re: 67 only Dash
Would you take 125.00 shipped to 45103?
Re: 67 only Dash
Best I can do is $160 shipped. Shipping is a little over half of that. Because of box size I get hit with weight of 80lbs even though it only weighs in under 30.
If you only need the center section I can cut it behind the cluster and glove box as well as along the dash pad and ship is for $125. Cut would be similar to this one.
Junior Member
Re: 67 only Dash
That's a good possibility, do you think you could cut it an inch or more wider and still box it? I'd like to splice in straight areas. Also maybe cut the lower left corner somewhere in the hoop for the steering column, one less area to finish.
If so I'll take it. |
![]() Join Date: Dec 2013
Re: 67 only Dash
67km1590 ask if he can cut it like this red section in the picture . It's worth an extra shipping charge to work it this way . Then you can just drill the couple spot welds on the bottom and not have to cut the support thats already in your dash and you end up with a lot less body work .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Re: 67 only Dash
I can cut it to the dimensions inside the white tape as shown without extra shipping charges. If you want it, my PP link is below in my signature. Thanks
Junior Member
Re: 67 only Dash
Thank you Grumpy old man, thats exactly what I had in mind. I'm new and haven't got around to posting photos yet.
And yes richard 2717 that cut is fine. I'll send you 125.00 to your paypal acct in few minutes and PM you my address. Thank you for the response. |
Re: 67 only Dash
Cut, boxed and labeled for tomorrow pickup. Thanks
#13 |
Junior Member
Re: 67 only Dash
That was fast, I like how you do things. Thanks
#14 |
Re: 67 only Dash
Since the deal is done I will post that I live in 45103 zip also. Batavia area near county jail.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
#15 |
Junior Member
Re: 67 only Dash
Would you happen to have the sharp light green (maybe 503) 67 short step I'ves seen around? We have a heavy truck and equipment repair business in Batavia. I'd like to see your truck up close sometime.
#16 |
Re: 67 only Dash
Here is what using the dash section cut and installed this way looks like when done , it's really the best way to repair radio cut out damage . without a ton of body work .
#17 |
Junior Member
Re: 67 only Dash
That's what I'm after. I had a cut out from a 69 dash and got in welded in but what a mess, I would never make it look like I wanted. Also at the time I was new to all the differences in 67's and of course the ignition switch and lighter holes were wrong. I got back around to looking at it more and thought why would I splice it in where the cuts were so visible and hard to finish.
#18 |
Junior Member
Re: 67 only Dash
