Old 12-24-2003, 10:23 PM   #1
photoglg
photoglg's Avatar
Master cylinder question
I am installing the power booster with the front disk brakes and the dule master cylinder has an outlet for front and one for rear. the hole plugs read 9/16 and 1/2 do I have to replace the lines to match or what the hell, the outlets take the same fitting.
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 12-24-2003, 11:16 PM   #2
Randy70C-10
Randy70C-10's Avatar
I have a bad memory but I'm pretty sure that they take the same lines.
Randy70C-10 is offline   Reply With Quote
Old 12-25-2003, 03:04 AM   #3
Injected68LS1
Injected68LS1's Avatar
The line diameters will be the same but they use different tube nuts. They do this so you can't mix front and rear. Most parts stores will have new tube nuts that you can use on your line. Just cut off the old end, slide on tube nut, and flare the end with a 45 degree flaring tool.
Hope that helps.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
