Frame mount brake booster?
Apparently in a previous life the stock brake booster bracket was cut off my frame( 55.2frame)Do any of you wonderful fellas have pictures or dimensions of where I should mount the booster. I can fab a new bracket, or just weld on the one that came with the kit . Anything helps I’ve looked everywhere.
Re: Frame mount brake booster?
I’m pretty sure it goes somewhere in this area,
mr buck: I have a spare mounting bracket for the under floor m/c. PM me and lets talk. Im not sure it will work with the pedal you have. Mine has stock pedals
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! Last edited by nvrdone; 08-21-2021 at 11:54 PM. Reason: spelling |
whoops. didnt see yours is a 55.2 - mine is a '49. does anyone know if the frames are the same?
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
AD's and TF's are not the same frame, if that's what you're asking.
dsraven- that manual is by far the most informative thing Ive ever seem regarding building a truck. Thanks
but it doesn't help me with dimensions of where the bracket sits. i need to know how high on the frame rail the mounting bolts are and how far behind the body mount bracket. i know tons of you guy have these on your trucks, anyone got pictures? |
thats what i was asking
check sheet 18 section 2 for how the bracket attaches alongside the forward cab mount and is rivetted there with the cab mount I think, cant remember exactly. sheet 24 section 2 has a few dimensions. the pivot for the pedal is off the front of the master cyl if memory serves.
here is a pic of one of my old frames. unfortunately the bracket is gone but gives an example of the frame bolt holes in the area., I suppose it is like yours anyway though. maybe somebody here has a pic relative to a stock pedal set up? or pm orrieG maybe, I think he has a stock brake set up? |
there is a bracket on the frame that the original master bolted to. does your new system bolt to that or does the instruction say to remove that stock bracket I'm wondering?
the new booster bracket is meant to mount to the original brake bracket. Im going to have to fab up the bracket its self, just need location info.
i will check the pages you said above |
#13 |
this is the bracket i will need to make, once i can figure out the dimensions.
#14 |
#15 |
![]() Join Date: Sep 2011
Maybe I missed it but you may want to say if your truck is a 1/2 or 3/4 ton to get the right bracket. Good luck . Looks like 58 Cameo Has you fixed up .
#16 |
58- thanks for the offer. I was able to find the dimensions and fabbed one up this afternoon.
#17 |
Pics…
#18 |
Also mounted the drop out battery box.
#19 |
![]() Join Date: Aug 2010
While you’re at it … make a drop out crossmember to tie the chassis together like the stock crossmember did . It is to keep the chassis from twisting from the weight on the front cab mounts . It goes a long way to keep panel alignment .
BTW the GMC version is a drop out type . Find one of those and save a bunch of time . I still have to cut and modify this one so the 4L60E can be serviced .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 Last edited by G&R's57GMC; 08-29-2021 at 04:10 PM. |
#20 |
G&R-- what brand sway bar do you have ? ive been looking around cant seem to pull the trigger on one yet.
#21 |
This is the first gen (2010) NoLimit wide ride IFS with air bag option, p/s . As I recall the sway bar was standard .
The cross bar in the front is from a friends IFS he didn’t use . I also used the NoLimit Fat bar rear set up with a Currie 9” . I took the chassis down to NoLimit when they were in San Bernardino ,CA and Rob installed it . It cost about $ 10k . When I left it was a roller on the wheels and tires and primer & paint I brought with me in the Avalanche in the background .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 Last edited by G&R's57GMC; 08-29-2021 at 11:22 PM. |
#22 | |
this is my version of a support system, very similar to what the custom frame builders do
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#23 |
it has an additional cross member welded in already. you can kinda see it in the second picture, its a horseshoe shaped bar that clears drive train . i'll see if i can get better picture. Also trans support still to go in as well.
#24 |
Kinda crappy picture but you can still see it
