08-21-2021, 08:01 AM | #1 |
*Flex Plate Dust Cover Plate*
I have a 2001 5.3 with a 350 turbo transmission in my 49. I bought a universal dust cover that was suppose to fit all 350's and it doesn't fit even after I tried modifing it. The starter is still hitting even with the cutout and the bolt pattern is off. Anyone know if there is a dust cover out there to fit my application?
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck |
08-21-2021, 09:00 AM | #2 |
Re: *Flex Plate Dust Cover Plate*
Just curious- How are you running the 350 turbo with the late model LS? Does it bolt right up?
current ride 1951 AD Chevy 5 window 2004 LS Gen 3 [/B] 1965 fleetside Sold |
08-21-2021, 09:12 AM | #3 |
When I bought the truck it was already set up this way. Looks like it bolts right up just like a 350 block.
08-22-2021, 11:10 AM | #4 |
I'm going to say that those are designed for pre 86 engines with a 2 piece seal and a 153 tooth ring gear and with anything else it is going to be trim to fit.
08-23-2021, 06:28 AM | #5 |
Thanks for the info.
08-23-2021, 12:33 PM | #6 |
Thinking about it, even the stock plastic ones don't always fit right on applications other than the exact setup they were designed for. The " I've got one hanging in the back shed" doesn't always fly there even though it is marked as having come off a Turbo 350.
