Old 08-24-2021, 03:07 PM   #1
Lethal Tendencies
Lethal Tendencies's Avatar
Kickpanel ventilation
My kick panel vents don't feel like they bring in much air. Should you feel any air movement coming out while driving?
Lethal Tendencies is offline   Reply With Quote
Old 08-24-2021, 03:16 PM   #2
Thealien
Thealien's Avatar
Re: Kickpanel ventilation
Is the cowl flapper open?
Yes you should feel movement if the flapper/door at the cowl is open.
These vents are notorious for filling with leaves and debris. Could be clogged also. There is a thread here discussing cleaning them out.
Old 08-24-2021, 03:22 PM   #3
Lethal Tendencies
Yes they are open. Just not getting much air through them. Going to check for debris this evening. Just wanted to get someone to verify that they actually bring in a strong amount of air
Old 08-24-2021, 04:05 PM   #4
Thealien
Thealien's Avatar
I wouldn't say "strong". But I do get airflow and its better than when the vents are closed.
Old 08-24-2021, 04:30 PM   #5
sick472
sick472's Avatar
I get enough pressure from them being open that it is actually quieter in the cab with the vents open and the back window cracked. They allow a fair amount of air to circulate into the cab given that you have a window cracked open so the incoming air has some place to exit the cab.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 08-24-2021, 09:45 PM   #6
Peanut74
As stated above make sure the vent flap under the vent cowl on the passenger side is open. Since the vents don't have a fan drawing air in you need to create a draft by cracking a window.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 08-25-2021, 08:39 PM   #7
70STOVEBOLT
70STOVEBOLT's Avatar
Where is the vent flap you are speaking of located?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 08-26-2021, 05:08 PM   #8
HO455
Post Whore
HO455's Avatar
You might want to take a look at this thread.
https://67-72chevytrucks.com/vboard/...d.php?t=825070
RIP Bob Parks.
Old 08-27-2021, 07:17 AM   #9
68panelman
68panelman's Avatar
These flaps are on the passenger side cowl and only on A/C trucks
68panelman is offline   Reply With Quote
Old 08-27-2021, 07:42 AM   #10
70STOVEBOLT
Ah, ok. My truck does not have a/c.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 09-03-2021, 11:55 AM   #11
purple gas
You may have a bunch of crap that's plugging them up between the vent and the cowl. My truck fills up with tree seeds & debris, I don't have a screen.
When I first got it it was jammed full.
Removed the cowl thing, air hose, a vacuum, and a piece of wire got it clean.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
