Low Fuel Light...Possible?
So I don't really trust my fuel gauge. I ran out once already when the gauge said I had 3/8 of a tank. As I was filling up this morning, I thought of a low fuel light when the tank only had 3 gallons left or so. I was thinking of using the tandem lock indicator on the dash for this light and changing the wording to "fuel reserve" or something. I have used low level sensors and such in fish tanks to signal water topoff, but obviously water isn't combustible...not sure about the sensor triggering a 12v source for the light. Any thoughts??
Moderator
![]() ![]() Join Date: Aug 2011
Re: Low Fuel Light...Possible?
Could you use a switch like this? https://www.amazon.com/Current-Sensi...a-660687002639
I honestly don't know...Is a low fuel light triggered by ohms like a fuel gauge or a separate float that triggers the light.
Moderator
I was thinking the switch would trigger a light?
Iirc, low fuel lights still read from the stock sender with a logic circuit to turn on the light.
![]() Join Date: Feb 2014
I have a low fuel sending unit it’s called a left turn comes on around a quarter of a tank 🤣
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
Have ya' considered putting a slight bend in the sending unit arm to adjust where the fuel gauge is pointing to? Just need to know roughly how many miles you get on a full tank and then adjust when it's close to empty. I'm sure a very, very small bend would make a big difference, then repeat to fine tune things if you have to. If you choose this route, tracing the arm onto a piece of cardboard for future reference would help take some of the guess work out of adjusting if it's not quite right the first time.
My truck ain't dead, it just smells funny. |
I am about to finish up some new wood bed...when I install it, I am going to try and come up with something or just keep filling up when the gauge reads just below half. I am not getting the best MPG either...and it isn't consistent. I have gotten 19.9 once (awesome) and below 10 once (UGH)...but usually hovers in the 11.5-14 range...usually towards the lower numbers. I just thought with a new crate engine and an EFI system, I should get around 15 minimum. Most of my drives are on a divided highway at 55-60 MPH at 8-10 miles...then a little city driving. Maybe I just need a better tune, but that is an entirely different thread....
Mostly was am brainstorming ideas to have a new light in the truck that is useful.
OK, so I finally found a thread on a truck forum that shall not be named...and they have this same basic thread...and someone used this voltage comparator tapped into their sending unit wiring.
Basically it has 12v power & ground to the comparator and a light 12v and ground, then adjust the brass knob until the desired voltage level to turn the light on. For $5 I may try it. |
Moderator
Cool, for $5 you can't loose.
#11 | |
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
#12 | |
#13 |
Also saw this metermatch It can trigger light for a low or high setting and adjust the fuel gauge readings...can also be used for temp, oil gauges, etc. but pricey.
#14 |
OK, so I just ordered a MeterMatch direct from the MFG for $65 shipped...hopefully it will solve my issues and give me the low level light I want. Will update after I install it.
#15 |
Any updates on this? I'm thinking of doing this as well
72 C10 lwb fleetside -stock 350/350 combo |
#16 |
Unfortunately not. I did buy the metermatch, but got caught up in life and now moving across country. I will get around to it, but I am not the fastest sometimes.
#17 |
![]() Join Date: Mar 2011
Where are you moving to?
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
#18 |
Yeah, it's sound activated........the SLOSH.
GoTennTitans 1987 GMC Sierra 1990 GMC Sierra (stolen) 2003 Chevy Silverado |
#19 |
Well maybe not moving across the country, but moving up the east coast 1000 miles...to the Syracuse, NY area.
#20 |
You'll need to cut open the tank and add baffles to keep the fuel from sloshing, or else the light will be flashing on and off constantly.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#21 |
Ah, good call
#22 |
![]() Join Date: Jun 2007
I don’t think it would be a problem until probably a quarter of a tank? That’s usually about where I fill up anyway. It will be interesting to see how it works.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
#23 |
I wonder if it would be possible to use one of these? https://www.camarocentral.com/1968_1..._p/con-29a.htm
#24 |
Moderator
The simplest hookup would be +12v and ground to the left blue block (#1 and 2). Then tap into the two wires going to your sender and connect to the white connector (#10 and 11).
Attach the full gauge voltage to 10 and the sender return to 11. If you are almost empty, the wire on 11 will be much lower voltage. Adjust the screw (9) to internally reduce the reference voltage on #10 until the relay trips, sending +12v power to the light from relay #5. Done. If the tank has more fuel (and more sender voltage), the light is off. https://www.ebay.com/itm/40120428441...IAAOSwPzhZ8p1A
#25 |
Master Chief,
Thanks for posting that info. Besides my 64 C-10 I also own a 62 Pontiac. Many years ago I bought a Speedometer cluster with the Speed Alert & Low Fuel light option for my Catalina. It didn't come with electronics to make the Low Fuel light come on. Once I get my truck finished then it's on to my Pontiac to get it done. |
| Bookmarks |
