Old 08-25-2021, 10:42 PM   #1
SkidmoreGarage
Kick panel vent bracket
I painted and refurbished my kick panel vents this week and I lost the bracket that holds the manual control rod against the kick panel. Anyone know where to buy just that bracket?
Here are some photos of the vents after refurb. I used silicone sheet to make the gasket.
SkidmoreGarage is offline   Reply With Quote
Old 08-25-2021, 11:44 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Kick panel vent bracket
I should have one. I will check in the morning. What year is your truck. I can't remember off the top of my head if there is a difference in them or not....
Vents look good!
LockDoc
Leon
Old 08-26-2021, 01:19 AM   #3
SkidmoreGarage
Thanks, they turned out pretty well I think!
Mine is a 67. It has two screw holes and a spring arm to hold tension on the rod.
Old 08-26-2021, 06:13 AM   #4
BigBird05
If its the same as a 1970 i've got one you can have.
BigBird05 is offline   Reply With Quote
Old 08-27-2021, 03:10 PM   #5
HO455
Post Whore
HO455's Avatar
The ones in my 67 look like this.
RIP Bob Parks.
Old 08-27-2021, 07:51 PM   #6
BigBird05
Does you knob look like this?
Old 08-27-2021, 09:46 PM   #7
SkidmoreGarage
Those brackets look correct! I'll send you a PM
Old 08-28-2021, 10:08 PM   #8
402Bowtie
402Bowtie's Avatar
Side question: that vacuum piece is for a/c trucks right? Is your's OEM, and is it a metal or plastic housing?
402Bowtie is offline   Reply With Quote
Old 08-28-2021, 11:21 PM   #9
SkidmoreGarage
It's all original and all metal.
