Old 08-26-2021, 01:46 AM   #1
68ls1
68ls1's Avatar
Upper Rear Shock stud loose
While replacing the shocks we came across where the upper shock mounting stud on driver's side is loose in bracket. I was unable to find anything on a google search or a search of this board.
What am I dealing with, as it is near impossible to get in behind bracket. Was this welded?
Is there a fix?
I couldn't find this in Assembly Manual, if it is there can someone please let me know page number.
Name:  Upper Rear Shock Mount copy.jpg
68ls1 is offline   Reply With Quote
Old 08-26-2021, 04:23 AM   #2
Spf79
Spf79's Avatar
Re: Upper Rear Shock stud loose
I had the same issue. I pulled the stud tight and then tacked it in place. It was the best I could do.
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 08-26-2021, 04:28 AM   #3
Spf79
Spf79's Avatar
I had better access, but you could tack it from the front?
Old 08-26-2021, 04:51 AM   #4
68ls1
68ls1's Avatar
I think that is what we do short term, body will come off at some stage then we can have a good go at it
Old 08-26-2021, 09:28 AM   #5
jaros44sr
jaros44sr's Avatar
I ended up replacing the whole bracket by drilling out the rivets
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-26-2021, 12:00 PM   #6
Tmend
Tmend's Avatar
I had same issue in both sides. Clean it up and weld it from front side. There’s enough space between stud and bracket to get weld. If you happen to weld to much the stud is long enough to put a flat washer the your shock and still get a nylon lock nut on.
Some progress is better then no progress
Tmend is offline   Reply With Quote
