Old 08-26-2021, 08:15 PM   #1
pwdcougar
pwdcougar's Avatar
Pitman arm bolt
For the life of me I can't find the pitman arm bolt for my 70 K10. Does it have to be a special bolt or can a grade 8 bolt of the correct size be used?
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 08-27-2021, 05:09 PM   #2
bob arrington
Re: Pitman arm bolt
a pitman bolts to the bottom of your steering gear/box and uses a big nut and washer, the idler hangs from a bracket on the opposite frame rail, any correct size grade 8 bolt will work for that but you need two
bob arrington is offline   Reply With Quote
Old 08-27-2021, 07:27 PM   #3
kwmech
Re: Pitman arm bolt
He has a K series and yes you can just get a Gr8 bolt and nut.
Old 08-27-2021, 10:43 PM   #4
pwdcougar
pwdcougar's Avatar
Re: Pitman arm bolt
Thanks that’s what I went with. Luckily there is a real old school hardware store nearby where you can get one grade 8 bolt one lock washer and one nut.
Old 08-28-2021, 12:16 AM   #5
kwmech
Re: Pitman arm bolt
If I remember correctly it was 9/16''?
Old 08-28-2021, 08:35 AM   #6
BigBird05
Re: Pitman arm bolt
If you want a factory bolt, send me the size you are looking for and I will go thru the mystery box and look for one. PM me so I don't loose your response.
BigBird05 is offline   Reply With Quote
