Old 12-25-2003, 09:49 AM   #1
Frankd
mastercyl and booster
I am making one truck out of three, I have a 72 cab I am putting on 68 frame With 67 front clip.My question is : I want to use the power brake booster and master cyl rrom the 72 with the 68 drum brakes (72 front suspension is bent) will 5this work? gonn use a stock 305 - no racing just cruising so drums should be enough. I have already shortenend the frame for a short bed, getting ready to start putting things together then I can start on body.
MERRY CHRISTMAS
72 c-10
81 c-30
67 c-10 just sittin in the woods)
70 C-10 " " " "
to compleete frames 67, 70 - in woods
2002 toyota tundra.
12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker
Frankd is offline   Reply With Quote
Old 12-25-2003, 12:35 PM   #2
dinnut
dinnut's Avatar
you will need a new master cylinder. the master cylinders are different from drum/drum to disc/drum. the prop valve is different also.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-25-2003, 03:04 PM   #3
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
The brake booster will be just fine, but you will need a new master cylinder (Just like dinnut said).
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
