Old 08-28-2021, 12:00 AM   #1
mismith
Anyone running Torq Thrust 17x7 front and 17x8 rear?
I’ve decided on buying a set of VN309 TT O for my ‘66 short fleet. I’ll be doing a 3/4 drop and it already has discs up front.
I can’t decide on 17x8 all around or use 17x7’s in the front? The 17x7’s only have a 4” BS and the 17x8’s have 4.5” BS.
A couple of my truck junkie friends are telling me to use the 7’s up front but I’m not convinced.
Is anyone running this setup? I sure cannot find any pics. online or any other posts concerning my question. Please post pics. if you have this setup!
Thanks!
mismith is offline   Reply With Quote
Old 08-28-2021, 08:08 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Anyone running Torq Thrust 17x7 front and 17x8 rear?
I have VN615's with 16X7's up front with a 4" backspace and 17X8 in the rear.
Old 08-28-2021, 09:05 AM   #3
mismith
Can you post pics?
Old 08-28-2021, 09:45 AM   #4
kens65fb
What size tires?
kens65fb is offline   Reply With Quote
Old 08-29-2021, 08:40 AM   #5
The Rocknrod
Moderator
Originally Posted by mismith View Post
Can you post pics?
Old 09-06-2021, 01:51 PM   #6
SCOTI
SCOTI's Avatar
Thanks!
This is a common deal but only works well when you can match tire width/heights appropriately (which can get harder to do when the wheel diameters get larger).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 09-11-2021, 02:40 PM   #7
Pitpig
Will you need two spares if you offset sizes?
Pitpig is offline   Reply With Quote
Old 09-11-2021, 03:47 PM   #8
Warrens69GMC
Warrens69GMC's Avatar
Not if the OD of the tires are the same
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-11-2021, 04:42 PM   #9
The Rocknrod
Moderator
Or a AAA card.
Old 09-12-2021, 12:16 AM   #10
SCOTI
SCOTI's Avatar
Or a AAA card.
Or.... Treat the situation like a newer cars (late 70's - a few years ago) set-up that utilizes a 'TEMP' spare to get you to your next destination. One wheel/tire used as a temp gets it done until the situation can be corrected. Something close enough/between the different sizes will get the job done.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-19-2021, 09:08 PM   #11
MT65
Or a AAA card.
That’s why the rollback tow truck was developed 😉😉😉😉
MT65 is offline   Reply With Quote
