still buypickupparts
I need to Identify this
ok i bought this 72 fleetside from a guy, he dont know what the motor size is. he says its a 86 crate motor. the #'s on the block say its a 350 as to chevy e-mail page. but guys I needed to buy a starter for it one time in the dead of winter, the 350 didnt mount because of hole pattern. is there a way to exactly know without tearing down the motor and checking cylinder bore size??. this sounds real bad but I cant identify what I have,, any help please |
Hoarding Rusty Objects
There are two different small block chevy starters that I know of. One has the two holes lined up, the other has them on an angle. You probably have the wrong one. A small block is a small block pretty much. Look whats on the block, straight holes or angled holes.
1985 Chevrolet K20 Silverado 1994 GMC Yukon Follow me on Youtube! - http://www.youtube.com/user/FuelInjectionSucks |
![]() Join Date: Oct 2001
Get your casting # and got to www.mortec.com maybe that will help!
Things happen for a reason! |
ok I see that. and I understand. but ya know how ya got something and it just drives ya crazy till you know exactly what you have. the guy I bought the truck from said he thought maybe the motor was a 305, but he realy couldnt rem. sheesh this is driving me crazy. the bolts on my starter are angled. it just drives me nuts maybe I have a 350???? maybe I have a 305, sheesh what is it???? help
2 years ago I sent them numbers to mortech, they said they would look into it because at the time they haddent seen them numbers, I told them it has stamped in the block made in mexico in it and I wanted to know what the real year was on the block, well they never replied and now on their page they show the numbers I asked about, but they show no year on the numbers, makes me suspicious that I sent them the numbers and they added the numbers to thier list and went with that.. NO I dont know but I have looked and e-mailed Mortech about this. I just still dont know what this block is.. is there a way to tell without ripping the darn thing down to find out is it a 350 or a 305??
someone told me the heads on a 86 would have center bolts in the valve covers is this so???
67-72 parts collector,…
![]() Join Date: Nov 2002
No. Center bolt heads started in '87.
fhew,,, thank you , I realy have never seen center bolts in a 86 but I wanted some one else to say it also
Does not matter as to engine size(262-267-305-307-327-350-400) as there are only 2 starters-one fits small flywheel -153 tooth-one fits large flywheel-168 tooth. You have angled bolt pattern so swap for straight bolt pattern.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
If its a stick it might have 3 bolt holes.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
Most all blocks have the 3 bolt holes. You can use either starter on all blocks. The flexplate or flywheel dictates which one.
The three holes he was talking about was for the manual transmission starter. for 67-72 then the starter bolts to the bellhousing for MT instead of the block. Bolts to the block on AT.
Is it a MT '72? If so, don't mention a thing about the engine being an '86, just tell them '72 pickup, 350 and a MT. They will get it right.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
