Old 08-30-2021, 09:24 PM   #1
Custom 68
Custom 68's Avatar
WTB 12 bolt rear housing
Hey all prefer local if possible I'm needing the wider 2wd 1971 1972 rear end. I really only need the housing but anything will be appreciated.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 08-30-2021, 10:41 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: WTB 12 bolt rear housing
How soon do you need one?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 08-31-2021, 07:43 AM   #3
Custom 68
Custom 68's Avatar
Unfortunately pretty quickly. I just confirmed I have an issue with mine I recently swapped. I'm planning on going to Cruisin the Coast in about a month so I am trying to swap it out. I have all the internals and new axles.
Thanks,
Dave
Dave
Old 08-31-2021, 11:30 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I assume you need a coil spring rear axle?
Don’t discount a 1970 housing.
Some of them are the like the wider 71-72 version except with 6-lug axles.
Keith
Convert to disc brakes.
Old 09-01-2021, 10:43 AM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I have a 72 leaf spring 5 lug if that would work for ya.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-01-2021, 10:55 AM   #6
Custom 68
Custom 68's Avatar
Thanks Keith, you are correct I wasn't sure exactly when the cutoff was. Yes it is coil spring setup but I will probably need to remove the brackets anyway to get my pinion set correctly. I had to do that on what is in there now.
Dieselwrencher, thank you I have put my feelers out here locally so I don't need to travel or ship and have a guy I need to call this morning as I believe he also has a couple to choose from. I will post in this thread and drop you a note when I have spoken to this local guy.
Again thanks all as this problem just reared its head and now I need to fix it...
Dave
Dave
Old 09-03-2021, 09:09 AM   #7
Custom 68
Custom 68's Avatar
Thank you all for your help and input. I have found one locally. I will tear into it this weekend and make sure it will work.
I didn't have many contacts for parts around here so I was concerned I might not find anything.
Thanks,
Dave
Dave
