08-31-2021, 12:01 PM | #1 |
v8 in 6cyl mounts what headers will work
i am taking the exhaust manifolds off and about to order headers. has anyone had any issues with headers thanks |
08-31-2021, 12:25 PM | #2 |
Re: v8 in 6cyl mounts what headers will work
I installed a basic set of Hedman full length headers with 1.5" primary tubes in my old '67 C10 SWB about 25 years ago. I had swapped the 6cyl for a V8, so the V8 was in the 6cyl position. The headers fit just fine. This was with an automatic transmission.
08-31-2021, 01:58 PM | #3 |
thanks i think it will be fine i just would like to order the headers one time im going to use the summit or jegs brand cheap headers just in case they need a few hammer marks
09-02-2021, 08:40 AM | #4 |
I used Summit SUM-G9006-SS stainless headers. They work fine with my SBC 350 in the I6/4X4 SBC position and 700R4/350TH.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
09-03-2021, 02:54 PM | #5 |
thanks for the reply.. i was going to pull the exhaust manifolds off and order the headers but i broke 3 bolts off in the head. i could not get the back one out because the engine is so far back. i pulled the engine out... now when i put it back in i am going to put it back in the v8 location.. easy header swap turned into headers cam intake carb radiator and powersteering good thing i sell truck parts ...
09-03-2021, 09:50 PM | #6 |
don't forget driveshaft!
