Old 09-02-2021, 01:34 PM   #1
desert-rat
Location: 3,018 feet above the SoCal/Mojave Desert region.
Does this steering column look right.
This came out of my '69 3/4 GMC. I thought 69-72 were 2 piece. Well, the body shop removed it and I'm not sure if everything is here. The rag joint is on the gear box. So does this connect directly to the gear box?? Thanks.
desert-rat is offline   Reply With Quote
Old 09-02-2021, 01:53 PM   #2
Thealien
Thealien's Avatar
Re: Does this steering column look right.
picture is not loading?
Old 09-02-2021, 01:57 PM   #3
Cannot see the picture, but the column has an intermediate shaft (collapsible) that connects the column to the steering box.
Old 09-02-2021, 02:10 PM   #4
desert-rat
Picture uploaded. Forgot. 😆
Old 09-02-2021, 02:16 PM   #5
Grumpy old man
Grumpy old man's Avatar
That's a 67 column . Yes that connects to the box
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 09-02-2021, 02:29 PM   #6
desert-rat
I wonder how our why a '67 column ended up in this truck. Well, it's been working, I guess I'll reuse it.
Old 09-02-2021, 02:29 PM   #7
desert-rat
How do I know a bad steering column??
Old 09-02-2021, 04:55 PM   #8
BRL
BRL's Avatar
When you turn right and the dang truck goes left!
Couldn't resist.
Hey Grumpy, anything you don't know about these trucks?
BRL is offline   Reply With Quote
Old 09-02-2021, 05:31 PM   #9
Grumpy old man
Couldn't resist.
Yep , I have no idea when I'll ever finish changing things , Project creep is a disease and I tested positive . There are a ton of guys in here that can rattle off part #'s by memory , and build customs better than Chip Foose.
