Old 09-04-2021, 09:48 AM   #1
eric8
Seat edge support springs
My seat is collapsing on the drivers edge and I can feel wire poking through, which I’m assuming is one of the seat edge springs as shown in the LMC diagram (item #4). Anyone replaced these before? How many are used per side? Can they be replaced from the bottom without removing the upholstery? I haven’t had the chance to pull my seat out yet and it’s hard to see up under there. Thanks!
eric8 is offline   Reply With Quote
Old 09-04-2021, 12:40 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Seat edge support springs
Look up TKCR She does seat on the board. Her work topnotch
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-04-2021, 12:43 PM   #3
Pontiac1976
http://67-72chevytrucks.com/vboard/s...d.php?t=715398http://67-72chevytrucks.com/vboard/s...d.php?t=715398
Old 09-04-2021, 01:05 PM   #4
Pitpig
I’ve replaced them, I think it comes with one per side. My problem was the outer horizontal spring was broken in several places. You can probably pull upholstery back, fix spring and hog ring or clip back
Pitpig is offline   Reply With Quote
Old 09-04-2021, 01:56 PM   #5
TKCR
TKCR's Avatar
They do only come 1 per side, but you can add up to 3 per side. I do 2 per side. And it’s almost impossible to replace these, unless the seat is completely torn down and the foam is removed. And there’s no hog ringing a broken spring. I have seen so many jimmy jack repairs when it comes to these broken springs. Fix the things the right way, install new springs.
This what I see the most, people but a block of foam in there. Again, you go to all the trouble of stripping the seat, then why not fix it right.
Old 09-05-2021, 08:18 AM   #6
Pitpig
Was probably unclear there, hog ring the upholstery back after fixing the springs. You can make the spring yourself with right gauge wire. Not restoring a rolls here and jimmy-jacking is an American tradition
