09-12-2021, 12:00 PM | #1 |
Question
Is a 62 c60 cab and doors the same as a 62 c10 cab and doors?
Thanks for any help. Bill
i have 67/72 chevy truck parts f/s. |
09-12-2021, 03:11 PM | #2 |
Re: Question
The doors and most of the cab are the same. There's some differences in the floor and transmission tunnel area between the two.
On the cab and doors that were used on the truck with the shorter nose, the bottom, front pillars are different and the bottom, front corner of the door is cut to accommodate the front end being shorter. I don't remember if some of the C60s had the short nose, or if that was for the even heavier duty trucks
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-12-2021, 03:41 PM | #3 |
Re: Question
The cab and doors I was looking at looks like the truck you have in picture below with wrap around windshield and doors are square at bottom. Thanks bill
