Thread Tools
Display Modes
![]() Join Date: Apr 2017
Electrical Question for Dim Headlights
Hello Peeps,
Got a question and not sure where to turn. My headlights are dim, when I rev the motor they get brighter, at idle they go back dim. I thought it may be a grounding issue so I changed the battery ground and added a better ground to the headlights. so Im clueless at this point.... Im sure its an easy fix except Im not that knowledgeable about it. I appreciate it, John
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
![]() Join Date: Dec 2013
Re: Electrical Question for Dim Headlights
Check battery voltage at idle - sounds like alternator is not putting out at idle.
Will.defintely try that...Thanks so much
![]() Join Date: Mar 2006
You may want to install a couple of relays up near the voltage regulator / horn relay. Taking power directly from the alternator/generator to the relay will eliminate the long run to the headlight switch and the high beam switch. Do a search for "headlight relay" on this forum - you should find several wiring diagrams for the relays. It made a big difference with my headlights.
![]() ![]() ![]() Join Date: Jan 2018
I remember having that same problem on my truck. After I put the headlight relay harness on, I think that issue went away, but I'm not remembering for certain if that's the case. Since I'm not remembering correctly, maybe that means the relay harness fixed that for me.
If your truck doesn't have a relay harness, definitely add one. They aren't too expensive, easy to install, and well worth the money. The stock headlights in my truck got way brighter with the relays. One of them burned out a couple weeks later, but then I was able to swap to some halogen bulbs which were even better. At the moment, my c10 throws better light than my 95 Dakota. Apparently, Dodge didn't start using headlight relays until some time after 1995, so that'll have to get fixed at some point too ![]()
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Too many places to lose voltage on the power side of the circuit. Relays should solve that problem
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Moderator
![]() ![]() Join Date: Aug 2011
For your year truck here is a great thread with great ideas on how to do it along with many links on the subject. http://67-72chevytrucks.com/vboard/s...d.php?t=397695
#8 | |
My 75 had that problem. Switching from the 10SI Alternator to a 12SI fixed it. The 12SI puts out about 7 amps more at idle then the 10SI.
If you are still running an externally regulated alternator, swapping to an internal regulated when you do the re-wire might be a good idea. BTW, the internally regulated 10SI and 12SI both use the same connectors. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
check my FAQS in the threads at the top of the electrical forum page.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
You have some real good replies here. Also check the battery. A bat. getting weak can cause that also.
George |
