Dyno'd my truck the other day
I used the chassis dyno at work a few days ago. After a little tuning on the computer I ended up with the following:
301 hp @ 5800 rpm (still made 300hp @ 6300) 313 ftlb @ 4400 rpm That's with a completely stock LS1. I do have a custom intake pipe, dual exhaust, and a programable ECU. Not bad through a 700r4 automatic. I was very happy. The ET estimates for that and my 3500 lb truck(3650 with me) is 13.3 seconds.
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
very cool, good job
75 GMC C-15 short/step factory 454, lowered |
Ebay Junky
i thought an LS1 vette motor made 345hp? is that an f-body motor?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
The 345 hp rating for the LS1 vette is at the flywheel, not at the rear wheels. When you factor in the typical 15 to 20 percent drivetrain loss, his 301 hp is probably 350-360 hp at the flywheel, so I would say that his motor is as strong or stronger than a typical vette. The only difference between F bodies and vette LS1's is the exhaust, which he has changed over to something more similar to the vette as I understand it.
Very well done!! I hope my conversion comes out as strong as his. I am using Hooker long tube headers on my LS1 project, so I am hoping to at least equal these numbers.
Tmax 1967 Chevy C10 Longbed Fleet 1970 Chevy C10 Longbed Fleet 1971 Chevy C10 Shortbed Fleet (Currently getting a 99 LS-1) 1941 International KB-5 Streetrod(Chevy 350/350TH Powertrain) |
That's true Tmax. I'm actually using the factory corvette exhaust manifolds. They're almost layed out like headers. I'm actually changing the exhaust soon so I'll probably pick up at least 10 horse.
Can't wait to see your conversion. Have any pics??
Formerly yellow72custom
Sweet power numbers! I remember reading in Popular Hot Rodding that the LS1 was under rated....they dyno'd one in a Trans Am and it had like 299 at the rear wheels.
Sounds like a fun little truck ![]()
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#7 | |
If patience is truely a virtue, Then I am so screwed 1970 Chevy SWB 331 sbc and all the goodies. Under resurection 2001 Vette |
Happy to be here
![]() Join Date: Mar 2000
Injected68LS1 , Did you do a print out? I would really like to see the hp/tq curve.
I have a 99 LS1 in my 82 Blazer with a 4L60E, and 3.73 gears. It has a set of Street & Performance "shorty" headers, and a true dual exhaust, with hi-flow cats. I am curious to see your curve, so I can guess how my combo would perform.... ![]()
I have to pull the graph off of the dyno computer. I'll post it soon. I still have some tuning to do. I'm missing some torque down low.
Happy to be here
Thanks, post it when you can....
