Old 09-16-2021, 04:27 PM   #1
rough69
rough69's Avatar
TH350 pro needed
I'm rebuilding the TH350 in my newly acquired '71 GMC 2500 which was rebuilt but had 3rd gear frictions burnt up and no drive gears whatsoever.
Everything is going smoothly, but when I split the pump halves, the old washer style (#3231580) pump has what seems to be a small valve in the front pump half.
I only found one exploded diagram online which shows what I think is a spring that should be behind the highlighted area that is missing.
Any idea where to find this or what I should call the little (pressure relief?) valve here? Can it just be omitted? Would the missing spring cause failures?
Also the kit I bought gives you new split teflon stator rings instead of steel lock rings like the original pump has. Is it ok to run these or do I need a different steel stator ring kit?
From what I've seen some builders also omit the second sealing ring for "dual feed"? Is this something I should do?
rough69 is offline   Reply With Quote
Old 09-16-2021, 10:16 PM   #2
60case
Re: TH350 pro needed
The valve is called a priming valve There should be a spring under it With out the spring you have a line pressure leak. Teflon rings are fine. Dual feeding direct clutch is fine but other things need to be done
60case is offline   Reply With Quote
Old 09-17-2021, 07:00 PM   #3
rough69
rough69's Avatar
I appreciate that I just put a spring behind there that fit as no one seemed to carry it.
Is there a write up on the dual feed modification? All I can find online is pull the inner seal from the direct drum and not the two on the piston, and to block the reverse port in the front where the pump is along with leaving the second ring out. Does that cover it all?
Old 09-17-2021, 07:36 PM   #4
60case
https://nastyz28.com/threads/th350-r...iy-post.53671/ look at this page
